Suspected dirty injectors - Page 2 - Diesel Forum - TheDieselStop.com
 2Likes
post #16 of 31 (permalink) Old 01-10-2019, 06:48 AM
ArcticDriver's Avatar
Originally Posted by bluenavigator View Post
For the state inspection, they only checked the thickness of remaining thread. I hadn't get the tires balanced yet. I am going to do that this weekend or next.
Oh, you mean the tire shop do the inspection on the tires? Doh! My bad!
I have always used Discount Tire for my vehicles and when they balance a tire, they perform a thorough visual inspection while its on the machine. Especially if you mention the truxk sat for a couple years. No doubt they have a business interest in finding damage but I bet they have saved alot of roadway blowouts and lives with this practice.
SOLD:
ArcticDriver is online now
post #17 of 31 (permalink) Old 01-11-2019, 03:16 PM Thread Starter
bluenavigator's Avatar
My Photos: (5)
Got my tires inspected and balanced. Only one went bad, need 14.5 grams lead. That tire was trashed. Drove my truck again. Guess what? Shaky gremlin is still there. *sigh*
Bluenavigator
'95 F-350 XLT PSD, CC, 2WD, Garrett Turbo AR 1.1, 5spd ZF tranny, LUK, 4.10 Limited Slip, just added Dual Arm Tenisoner. Just added my ol' vacuum gauge to monitor my vacuum pump.
bluenavigator is online now
post #18 of 31 (permalink) Old 01-11-2019, 04:35 PM
bugman's Avatar
My Photos: (12)
I had a set of tires that gave me a vibration no matter how they were balanced. If a certain tire was on the front I would get vibrations at 50-60mph, if it was on the rear the vibration would show up between 70-80mph. I loved it when I got rid of them.
So, have you had your drive line checked to see if it is balanced, checked U-joints? No bent axle?
bugman is online now
post #19 of 31 (permalink) Old 01-11-2019, 04:49 PM Thread Starter
My Photos: (5)
The tires, after being balanced, were mounted back to opposite corners/sides as rotated. The shaky gremlin came back at same speed range. I have replaced all three u-joints. The drive shafts wasn't checked but from visual check, I do not see anything that showed something being off or that they were bent at all. The only thing that was bent is the spare tire carrier as it was bent when it was not put up while driving backward. My mistake. I can take it off and have it fixed later but doubt that it has anything to do with the vibration but it wouldn't hurt to have it removed and see if anything is different.
Bluenavigator
post #20 of 31 (permalink) Old 01-11-2019, 06:35 PM
bugman's Avatar
My Photos: (12)
The drive shaft doesn't need to be bent but can be out of balance. If you look at a lot of them you will see balancing weights attached to them
post #21 of 31 (permalink) Old 01-11-2019, 08:50 PM Thread Starter
My Photos: (5)
Yea, I do see weights attached to the shafts. They are still there.
Bluenavigator
post #22 of 31 (permalink) Old 01-11-2019, 09:26 PM
Patrick Feeley's Avatar
My Photos: (19)
How's the carrier bearing? Not that I know (and maybe somebody here can chime in), but don't the sections of driveshaft need to be "phased"? Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #23 of 31 (permalink) Old 01-11-2019, 11:12 PM
Well you are still better off to have had the work done and eliminate one more possibility.
So here is a thought, have you driven the truck in various gears to determine if the vibration is speed related or RPM related?
Agree that a carrier bearing could be worn out. They should be snug and not sloppy when gripping and shaking the driveshaft by hand.
SOLD:
post #24 of 31 (permalink) Old 01-12-2019, 12:30 PM Thread Starter
My Photos: (5)
Yes, I had the mid-section carrier replaced once back in 2000. I didn't feel anything from that one. Someone mentioned to check this part back in 2000 on this forum, under different name (pre-thedieselstop). From that, I just went up and checked it out. Sure enough, that it is really loose, not snug at all. Had hard time take it out but put new one on, it is smooth sail.
Today, I am going to attach GoPro cameras and monitor the under carriage.
Side note: I am deaf, which poses another problem, unable to hear certain noises, necessary to diagnose the whole thing.
Bluenavigator
post #25 of 31 (permalink) Old 01-12-2019, 11:11 PM Thread Starter
My Photos: (5)
Update: I had my friend ride with me. He suspected flywheel being unbalance. Oh great...
Bluenavigator
post #26 of 31 (permalink) Old 01-13-2019, 12:13 AM
I would look other than the flywheel. I don't think I have ever seen a post about that being a problem.
DENNY
1999 F350 AUTO 4x4 CC LB DRW 4.10
DENNY is online now
post #27 of 31 (permalink) Old 01-13-2019, 02:05 AM
klhansen's Avatar
My Photos: (180)
If you had the dual mass flywheel, that could be a possibility if it puked a spring out. But the thing is about a flywheel being out of balance, is it would be evident at all speeds, even when sitting still. It's possible that it could amplify at certain speeds/engine rpm's because of harmonics, but I'd be doubtful it's the flywheel. It can easily be tested by revving the engine while sitting still.
), AIS,
regulated return,
klhansen is offline
post #28 of 31 (permalink) Old 01-13-2019, 12:11 PM Thread Starter
My Photos: (5)
Yea, I had that experience before replace it with LUK.
Just few minutes ago, my hearing daughter rode with me. She said that it is nothing from transmission. However, there is subtle knocking noise, more from the front around tires. It is not loud but it is there. My next guess is to check the bearings and spindles. That is better than pulling the transmission for sure!
Bluenavigator
post #29 of 31 (permalink) Old 01-13-2019, 07:19 PM
If you have already replaced u-joints in the front axle then possible bad wheel bearings?
I feel like I am just throwing darts at the wall at this point.
SOLD:
post #30 of 31 (permalink) Old 01-13-2019, 09:37 PM
klhansen's Avatar
My Photos: (180)
Your last dart (front axle u-joints) missed by a long way.
Notice in his signature he has a 2WD truck.
), AIS,
regulated return,
klhansen is offline
