Thermostat Housing ?gasket? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 02-09-2009, 03:01 PM Thread Starter
I changed my thermostat and my upper housing started leaking so I changed it and now its leaking between the two housings. Is there a gasket that goes between the two. I know there is an O ring type gasket that goes around the thermostat but what about in between the two housings? I tried silicone and it didn't work. All that the auto parts stores show it having just the o ring for the thermostat.
gulfcoast is offline
post #2 of 5 (permalink) Old 02-09-2009, 04:21 PM
just an therm o ring....the housing may be bad ...when I changed mine I used the therm o ring and some sealant around the edges no leaks....
/190K/5 speed/BDP Tranny Savers/Redline MTFin tranny/410 gears/open diff./No cat. conv./4" warped speed exhaust w/5" chrome tip/Gutted EBPV/3.5" downpipe/ Tymar open air intake/95 dana 60 / 6" skyjacker Lift/ Factory Manual hubs/HX hose/Ranch Hand Rear bumper/ Fumoto drain valve/Baldwin bypass/Coolant Bypass/Energy Suspension bushings(red)up front/bilstein 5100 shocks/Valeo clutch/31575R16 Cooper SST mt/K-9 Remote Security System/Mag Tech Diff. Cover/(ALF 6 Factory Program) TS 6 Position flip chip/Diamond Cut Headlights/203* Thermostat/Autometer Gauges/TSM Rear Disc Conversion
agomez is offline
post #3 of 5 (permalink) Old 02-09-2009, 04:55 PM
use rtv sealant around were the two housings meet. you can get a tube at auto zone for like 5-7 bucks
plowingdiesel is offline
post #4 of 5 (permalink) Old 02-09-2009, 07:52 PM
Patrick Feeley's Avatar
My Photos: (19)
Make sure the ears (where the bolts go through) of the thermostat upper housing are bent up just a tad (put the housing on a flat surface to check) prior to bolting it down. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #5 of 5 (permalink) Old 02-09-2009, 11:31 PM
169stang's Avatar
My Photos: (5)
I had the same issue. I used a high temp RTV sealant. Cured.
1997 F350 7.3L CC DRW 2wd
Tymar 3" DP, 4" exhaust, intake. Gutted EBPV, modified pedestal. True-Cool Max tranny cooler. Tony "Wildman" 4 position chip. Autometer gauges
2005 Mustang GT street/drag car. 76MM turbo 800rwhp
1996 Mustang Cobra Mystic #93
1969 Mustang Coupe-302
169stang is offline
