turbo o-rings - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 04-02-2014, 05:04 PM Thread Starter
turbo o-rings
My turbo o-rings have been leaking oil for awhile so its time to replace them. Is it better to install them dry or put a little oil/grease on them first? I think in the past I've used a little grease to help them stay in place and not fall out on me while putting everything back in.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters. SD starter. DP 80hp tuned PCM.
'04 F550XL reg. cab. ZF-6 speed. EGR delete. Coolant filter. Cat EC-1 coolant. LF777 bypass oil filter. Blue-spring fuel pressure regulator. ScanGauge II. Glowshift fuel pressure gauge.
'06 F350 xlt crew cab. 5R110 auto trans. 4x4. EGR Delete. DIY Coolant filter. Cat EC-1 coolant. Blue spring fuel pressure regulator. Open CCV. SCT X4 Gearhead Tunes. Dual SPA fuel/oil pressure gaugeWicked Wheel 2.
sdan27 is offline
post #2 of 2 (permalink) Old 04-02-2014, 06:37 PM
bugman's Avatar
My Photos: (12)
I would lube any and all O rings going into something that will be in contact with oil.
bugman is offline
