Unexplained hole in the manifold - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 10-11-2018, 04:36 AM Thread Starter
I recently added a tuner to my 97' F350. Unfortunately, I had to disconnect it because I did not realize the transmission had already been rebuilt and has a shift kit in it. The truck shifted so hard in every gear it was like it was going to destroy the rear end. A few days after I disconnected it, I noticed a sound like a pop off valve on an air compressor, but it sounded more like an exhaust leak. I noticed when I started it up, the sound would be real loud and then go away until I got in and gave it gas. I also noticed when I started it up it would blow the dirt on the ground just behind the driver side front wheel so I got under it and looked. I seen a hole in the manifold that looks like something was meant to be there. I am assuming that because there are no error codes, it was probably a plug of some sort. Does anyone have any idea what this could be? Hopefully the two attached pictures will help. Thanks
ocos50 is offline
post #2 of 13 (permalink) Old 10-11-2018, 05:23 AM
Audiowriter's Avatar
Might have been some brand / type of Pyro (exhaust heat temp) gauge sensor relay.
It looks like there was a metal strap around the doughnut bolt knobs that held the pyro sensor in place.
2 each - Stock - 97 F-350 7.3 PS 1 ton Duallys - RWD - AT
Audiowriter is offline
post #3 of 13 (permalink) Old 10-11-2018, 05:35 AM Thread Starter
Okay, please excuse my ignorance. This is my first diesel truck. Now that I am learning and beginning to work on it, I am really finding out how much I don't know. What is a Pyro sensor and could you point me somewhere I could see one? If this blew out or broke out, i need to see if I can replace it. Wouldn't there be some wires somewhere for it also. I wasn't really looking for anything like that so i could have missed it.
Thanks.
ocos50 is offline
post #4 of 13 (permalink) Old 10-11-2018, 06:19 AM
Pyro= pyrometer. Measure exhaust gas temps. Should be a gauge in the cab somewhere, or maybe a previous owner used a fancy tuner that read it digitally. Either way, I'd guess the new tuner gave you enough power to blow the thing out of what looks like a rusty hole.
AaronSEIA
My Truck:
97 F250 4 door shortbed, E4OD
DIY intake
Kingpin Dana 60
otherwise stock
AaronSEIA is offline
post #5 of 13 (permalink) Old 10-11-2018, 08:35 AM
79jasper's Avatar
Its possible they pulled the gauges and clipped the sensor off. Could be why theres no wires.
Sent from my SAMSUNG-SM-G930A using Tapatalk
79jasper is offline
post #6 of 13 (permalink) Old 10-11-2018, 10:59 AM
Welcome to the world of hot rodding Diesel trucks!! The above answers are most likely correct as to the reason for the hole. The probe is normally a NPT thread 1/8 ", this is a tapered thread. If you see no signs of wires near the location I suspect the probe was removed. The proper plug for the hole would be a 1/8' NTP plug (LOWES, NAPA, ect will have them). Hopefully The threads are still good and all you need to do is throw in a plug. It would not hurt to pick a tap and run it through before you put in the plug. Hopefully the previous owner did not try to stick a regular bolt in the hole and screw up the threads. You should consider some gauges (boost, EGT, tranny temp) if you are going to start modding you truck. Avoid any programing that touts "rolling coal" this is just a crappy program with improper fuel air mixture.
DENNY
DENNY is offline
post #7 of 13 (permalink) Old 10-11-2018, 12:14 PM Thread Starter
Just to clarify, there was not a tuner when I purchased the truck. The leak was not there for a long time so assume there was a plug. I will say that the hole diameter is definitely larger than 1/8 npt. I will measure when I get home. The gentleman that owned the truck before me bought it new and kept impeccable service records. I just missed the transmission rebuild when I glanced through them. He passed away and I bought it from his daughter for $4k and she had never driven it. No one I know or that has actuall looked at it has ever seen that hole before. That is why I am asking. Thank you for your comments so far. I just wanted to clarify those couple of things.
ocos50 is offline
post #8 of 13 (permalink) Old 10-11-2018, 06:22 PM
Mystery hole
I agree with the others, it most likely where a pyrometers threaded male end was inserted into the exhaust gas stream. That is typically a small stubby looking insert with wires coming out of it, the sensor threads into the exhaust and the wires are connected to a gage. Often the wires from an aftermarket sensor to gage are not adjustable in length, a sensor - gage calibration issue. So if you don't have a bunch of wires under there or in the cab then someone pulled the pyrometer system. They could have plugged the exhaust hole or just abandoned the sensor in place and either blew out. If there are threads you are good, just put some never sieze (Copper Blend high temp) on a plug. No threads, make some, maybe go up a size. If you do drill and tap anything into the exhaust use a magnet on a stick to get any shavings out before you plug her up. You don't want any shavings going through your turbo.
2002 F250 7.3L PSD, bought new now at 226K miles, 4R100 Auto, Crew Cab, Short Bed, ITP Regulated Fuel Return system, ITP head to head SS oil cross over, Hutch in tank mod
Harpoon de tank vent, DIESELSITE Dahl 100 Pre-Pump Fuel Filter, DIESELSITE Return Fuel Line Cooler, DIESELSITE Engine Coolant Filter, DIESELSITE Auxilliary Transmission Cooler, DIESELSITE Gage Package, Pyro, Trans & Boost, Extreme Diesel AD injectors, Ford AIS Air Filter System, BTM straight through muffler, Moog Ball Joints, Rancho Shocks, Rotella ELC Coolant ,Stock Engine Program
Modified for I-Pod Connection
We b playing Scotland The Brave to Jimmy Hendrix
Oneof6 is offline
post #9 of 13 (permalink) Old 10-11-2018, 06:31 PM
bugman's Avatar
My Photos: (12)
The hole may or may not be threaded, there are clamp on thermocouples that will go into the hole and then are held in place with a band clamp.
bugman is online now
post #10 of 13 (permalink) Old 10-11-2018, 10:34 PM
Patrick Feeley's Avatar
My Photos: (19)
I agree with bugman. I had a clamp-on thermocouple on my 94. It used the force of the clamp with a soft metal gasket to seal it against the manifold surface. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #11 of 13 (permalink) Old 10-12-2018, 06:19 AM Thread Starter
Thank you to everyone one that chimed in. I am going to clean the hole and see if the threads are okay. If not I will go up a size and plug it up. I purchased the Edge tuner pictured below and have to have it reflashed to remove the shift program due to the shift kit after the transmission was rebuilt. I will be adding the Exhaust Gas temp sensor to the system so I am hoping I don't have to go up a size. Thanks again. I will be on here a lot in the near future because I want to do some major performance upgrades over the next few months and I am new to this.
ocos50 is offline
post #12 of 13 (permalink) Old 10-12-2018, 07:13 AM
79jasper's Avatar
You can always Bush it down, if you have to.
Personally I like the threaded versions better.
79jasper is offline
post #13 of 13 (permalink) Old 10-12-2018, 11:05 AM
Using a reducer bushing if needed is a great ideal. Be careful trying to hot rod a truck older truck with high mileage. Lots of parts between the gas pedal and the tire that have to hold up to all the extra power.
DENNY
DENNY is offline
