Voltage drop on GPR - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 02-08-2009, 04:15 PM Thread Starter
Voltage drop on GPR
The voltage on my GPR drops 2 volts when the key is on. Is this normal? I have been having some cold starting issues. I read somewhere that .5 volt drop was typical.
jawmaw is offline
post #2 of 11 (permalink) Old 02-08-2009, 04:38 PM
Yeah, 2 volts is a bit excessive. If it's dropping two volts, and passing about 150amps, then it's dumping about 300W of heat in there, and it probably won't last much longer.
1997 F350 CC DRW E4OD POS. electric fuel, DIY6637, Beans Stage I. 200k and counting.
RD97 is offline
post #3 of 11 (permalink) Old 02-08-2009, 04:43 PM
Excavator's Avatar
My Photos: (11)
I think you might be confused.
The 2 volt drop you see should be how much the batts drop when you turn key on. I say this because when glow plugs are off you will see about 12.5 volts and when turn key on with glow plugs heating the bat volts drops about 2 volts. Now the drop of .5 volts should be max difference when you check each large post on GPR while GPR is activated and G Plugs are drawing
99 F350 Super Duty CCLB 7.3 Auto DRW 150000 miles, multi disk converter,Hydra chip with TW tunes,ISSPRO EV2 pyro fuel trans
1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60, Bilsteins shocks, BTS Trans, Baby
Swamps,Tony Wildman
Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
Excavator is offline
post #4 of 11 (permalink) Old 02-08-2009, 04:56 PM
My Photos: (61)
I think you're right, Excavator - most likely a 2v drop in the dash gauge when the glow plugs are active, not a loss of 2v across the glow plug relay.
How 'bout it Jawmaw? Is the dash gauge what you are looking at or are you checking voltage on the two big terminals on the glow plug relay?
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS
, LUK clutch, homemade
, open element
, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
post #5 of 11 (permalink) Old 02-08-2009, 05:17 PM
ford_doctor's Avatar
Better idea: Check the glow plug amperage to make sure your GP system is working correctly. Amperage should be 195 initially, tapering off to 125 after 30 seconds. An inductive clamp around the battery cable leading to the glow plug relay will do. You can test each side by putting your inductive clamp on each feed off of the relay, good results are about 90 amps initially.
2019 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #6 of 11 (permalink) Old 02-09-2009, 12:28 PM
sloate's Avatar
.5 volts is even a little much, .1 volt
1995
F350, CrewCab, 7.3 PSD Dyno at 390 HP, zf5, 3 in Down pipe with 5in straight pipe with stack, Tymar, DDP stage 2 injectors, Intercooled, Stole it at $2500! 400000miles! Going for 1/2 million
1989
L8000 Dump Truck, 7.8L , 6 speed Fuller, 315000miles
1964
F350, 24v 5.9 Cummins, New Nv4500, Np205, JD green paint "Built Not Bought" 0 miles,
sloate is offline
post #7 of 11 (permalink) Old 02-09-2009, 01:22 PM
Where are you seeing the 2 volt down at? Are you talking about a 2 volt drop between the two big posts on the glow plug relay? Or a 2 volt drop in battery voltage? If it is a 2 volt drop across the relay posts then your GP relay is bad. If it is a 2 volt drop in battery voltage I think one or both of your batteries are weak or your battery cables to the relay are bad. Just my 2 cents.
Griz
02 F250, 4X4, 4R100, 3.73, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, Tymar Intake & HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug, Riffraff FRx Kit. 6.0 Transmission Cooler. Dieselsite Coolant filter & Transmission filter & 203 Thermostat & WW2 & TurboMaster & inter-cooler boots. BD CCV filter. Driven Diesel Fuel Tank Mod & Pre-Pump Filter. John Wood's valve body.
Griz is offline
post #8 of 11 (permalink) Old 02-09-2009, 01:53 PM
Excavator's Avatar
My Photos: (11)
if he is seeing 12.5 batt volts with key off and sees 10.5 batt volts with key on and g plugs activated then that is good.
I am not sure when or where he is taking reading
Swamps,Tony Wildman
post #9 of 11 (permalink) Old 02-09-2009, 05:33 PM Thread Starter
I am taking the reading across the 2 big terminals on the GPR. Thanks for the replies. I will be replacing the GPR soon.
jawmaw is offline
post #10 of 11 (permalink) Old 02-09-2009, 07:21 PM
If you're dropping 2v across the terminals, replace soon as possible. With that drop it should be smoking by now.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
RonKZ650 is offline
post #11 of 11 (permalink) Old 02-09-2009, 09:43 PM
My Photos: (61)
I stand corrected. Biggest drop I have seen so far for a functioning relay.
Dave / Believer45
, open element
