White smoke from fuel tank. Looks like blow by. Any thoughts - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 07-16-2019, 08:48 AM Thread Starter
Jesse.a.arthur@gmail.com's Avatar
Hey fellas, i have a 97 7.3 psd 1 ton with all the upgrades done. Injectors, efuel, turbo and intercooler etc. i have white smoke coming from the fuel tank cap and vent. Havent found much on the 7.3 psd. Anyone have any thoughts? Injector orings? Thanks in advance
post #2 of 6 (permalink) Old 07-17-2019, 12:24 PM
klhansen's Avatar
My Photos: (180)
There shouldn't be smoke coming from the fuel tank cap. That would be something pretty strange and potentially serious.
Did you mean the oil fill cap on the engine?
Welcome to TheDieselStop.
), AIS,
regulated return,
klhansen is offline
post #3 of 6 (permalink) Old 07-17-2019, 12:52 PM
RT
RT's Avatar
Maybe sucking air somewhere and pushing it back through the regulator into the return line.
RT is offline
post #4 of 6 (permalink) Old 07-17-2019, 10:17 PM Thread Starter
Nah man. Fuel tank. Ive had the bed off. Its a white smoke coming from filler neck and the roller over check valve. Not sure on the sucking air part. I noticed fuel pressure dropped from 60psi to 40 psi. Smoke or vapor what ever it is doesnt smell odd like blowby does. I dont know im stumped
post #5 of 6 (permalink) Old 07-18-2019, 11:35 AM
BS Hauler's Avatar
Is your exhaust leaking and heating the fuel tank. We had a old gas powered pickup with a steel tank and the exhaust was leaking and the gas in the steel tank would actually boil in the tank from the exhaust blowing on it.
02 F350 Lariet CCLB 4wd Dually 7.3 6sp M. 122,000 miles, Manual hubs and transfer case.
Stock as of yet. So far have bought
4" MBRA turbo back with muffler
GTP 38R BB turbo and WWII wheel and high flow housing, Non EBV pedestal, Adrenaline HPOP.
New IH up-pipes, Aluminum intake plenums, 203* Therm with aluminum housing, Boost relief valve, all new boots, FPRx and HPRx. Coolant and Trans Filter kits. Max AC Assist control Valve. 8 gauges,
Boost,Pyro,Fuel,HPOP,LPOP pressure. Water,Oil and Trans Temp. Need tunes and injectors yet.
03 26' CM 4 Horse trailer and 25' GN flat bed.
06 F-350 Lariet CCSB SRW 4wd Auto 6.0 78,000
miles. Atlas 80 with Ed's lifetime, Blue spring, MBRP 4" turbo back with muffler, Bully Dog for monitoring. So far no problems.
BS Hauler is offline
post #6 of 6 (permalink) Old 07-18-2019, 01:01 PM Thread Starter
I was thinking that but It starts puffing smoke 30 seconds after start up.
