Wide open throttle - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 02-24-2009, 02:36 PM Thread Starter
Wide open throttle
First off I tried a search and did not come up with much on this. I was leaving a light and stepped on the acc pedal. The truck lurched and jumped and missed a couple of times and then took off like a bat out of hell. I let off the pedal when it started to fish tail and I was only a quarter down on the throttle. I finally had to turn it off to get the throttle to drop to normal.
blingn is offline
post #2 of 6 (permalink) Old 02-24-2009, 02:47 PM
drwoodchopper's Avatar
Could be a number of things. Throttle position sensor is the first to come to mind. You might want to include more info mods and such so the real guru's can help you out.
1997 F350 CC4X4 RSK RIDING ON 35's 3:55's, 230K, DP tuner 6 pos chip! IDM mod, Pyro, Boost and Trans Autometers over mirror. Oil and Water temp in hand built "hump cubby" 4" straight pipe! . ZF5 Conversion 6 leaker intercooler. Swamps 175/146 sticks fed by Adrenaline. WOP QSSB turbo e-fuel conversion and a custom CNG system, yea it gets like 32mpg's. 2011 6.7 F350CCSWB H&S Minni Maxx. My Youtube vid.
drwoodchopper is offline
post #3 of 6 (permalink) Old 02-24-2009, 03:04 PM Thread Starter
96 f250 7.3td, chipped not sure the brand. It has a air filter kit too. automatic
blingn is offline
post #4 of 6 (permalink) Old 02-24-2009, 04:50 PM Thread Starter
I was talking to a Ford diesel mech and he was saying to maybe change the oil. Dirty oil could be messing up the injection pump. ???? Does that make since?
blingn is offline
post #5 of 6 (permalink) Old 02-24-2009, 05:51 PM
ammayernick's Avatar
Throttle position sensor(TPS)
2011 F350 CC Lariat 6.7 4x4 Tuxedo Black Loaded* ICON 4.5 inch Stage II with 4 link and Deaver Mini-Paks * OUO 5" Traction Blocks & Bars * 20" BMF Novakanes with 37x12.50x20 Nitto Trails * ICON Dual Steering Stabilizer * RECON Projectors, Mirror, 3rd brake, Cab,and Tailights * Pace Edwards Bedlocker * EPIC Door Seal Mods * AMP Research Steps *
ammayernick is offline
post #6 of 6 (permalink) Old 02-28-2009, 11:20 PM
i had a bad ICP last year that made it snappy as heck and shift hard. Got it replaced. Experienced same snappy/hard shift yesterday messing around with the icp wires doing a 10 k mod. Also threw a cell. I thightened the connector to the ICP and all was good. Probably loose connector last year as well. Ford shop may have gotten me on that.
TRADED: 97 F250 CC SB 4WD 106,000miles. Tymar intake, IDM mod, shimmed FPR, CCV mod, 203 t-stat, coolant filter mod., MBRP 3-4" sraight through, HPXover, Wildman 6 position.
For the tranny some Schaffers, Tru-cool cooler, sonnex and springs and T/C lockup.
FOR A:
99F350 CC SB 4WD 130k Miles..Stock so far
fautnsmllit is offline
