ZF 5 speed- close or wide ratio - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 06-01-2005, 04:23 PM Thread Starter
Do you guys know how to tell which one is in your truck. Trying to figure out which one I have in the 94. I didn't know there was two. Origanaly I was trying to compare the gear ratios between the 5 and 6 speed. Thanks.
1994 F350 CC SRW LB 4x4 5 speed IDI Diesel
1997 F350 CC SRW LB 4x4 5 speed Diesel
2002 F350 CC SRW LB 4x4 6 speed Diesel
Cowboy350 is offline
post #2 of 12 (permalink) Old 06-01-2005, 05:59 PM
Re: ZF 5 speed- close or wide ratio
i think the difference is if it is for a 7.5 or 7.3. they have a little different ratio if thats what your looking for? [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
RYAN
GAUGES, INTAKE, EXHUAST, SBC CLUTCH, CHIP, BDP INJECTORS, BILSTEINS, BUSHINGS...AND A WHOLE LOT MORE..
B99 BIO DIESEL SUPPORTING AMERICAS FARMERS.
US NAVY
looking for an ext cab 4x4 short bed DURAMAX!!! keeping the obs of course.
1997PSD4ME is offline
post #3 of 12 (permalink) Old 06-01-2005, 09:14 PM
the diesels have the close ratio which sucks as far as gearing goes....and gas engines have the wide ratio which is a lot closer to the NV4500 ratios....also in 96 they updated the close ratios in the diesels to something closer to the wide ratio but still not the same ratio's as the gas engines...hope that helps
97 F250 Crew Cab 4X4 3.55LS E4OD TS 6 POS Chip MBRP 4" Exhaust Custom Intake Will Work For Stage II Injectors!!!
Wifes Ride
01 Excursion Limited Powered by Powerstroke!
ryanp is offline
post #4 of 12 (permalink) Old 06-01-2005, 11:04 PM Thread Starter
Thanks for the info. I got the ratio numbers from someone else on here when I asked this in the 7.3 diesel forum. They were the ratios for 6 speed and both 5 speeds. Now I know what I have in the 94.
Does anyone else know the numbers also.....see if there the same as my other numbers.
post #5 of 12 (permalink) Old 06-02-2005, 11:24 AM
i cant remeber if i saw them in my shop manuals or on steve baz's site or one of the other million places i've been too. but if i see them i will post it. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
RYAN
US NAVY
post #6 of 12 (permalink) Old 06-02-2005, 01:40 PM
My Photos: (32)
I thought we had wide ratio boxes because Ford felt the broad torque band of a diesel could drag the rpms back up when you encountered the big rpm drop of the greater spread between gears. I also thought that this is why the gear split between 3rd and 4th is so big...
With a close ratio box, the rpm drop between each gear would be smaller (and better) and we would be better able to use our small rpm range. When towing heavy, the split between 3 and 4 is too big, sometimes you can't get enough uphill speed in 3rd to be able to run 4th. I looked at the ZF6 also, and I recall that 3rd is much closer to direct (4th) than our ZF5s...
Needless to say, but I'll say it anyway [img]/ubbthreads/images/graemlins/grin.gif[/img].... "Correct me if I am wrong"
God Bless,
TC
97 F350 XLT, 4x4, Toreador Red, CC, PSD, MLE0, ZF5, 3.55 l/s, LUK clutch,Velvet Rides, ISSPRO gauges, v/cover vented to tailpipe, DPPI downpipe - modded to 4" right below firewall seam, open element intake using Duralite filter, coolant filter mounted between washer fluid bottle and jack, gutted EBPV, 99+ I/C installed using early 99 Y-pipe and custom pipes, 4-pos chip, BigBopper Seat Mod, Bilsteins, 130cc injectors, homegrown 4" exhaust, uses 36" Magnaflow muffler (Model #12773 body is a full 30" long - nice and quiet!) Custom Fuel System using Carter electric pump, Aeromotive regulator and frame-mounted filters...
2003 Tahoe MS27TT (27' Lite travel trailer), Prodigy Brake Controller.
1991 5.0 LX, runs 12.57 @ 109 mph
My Intercooler/Fuel System Install Webpage (section on CCV Mod too):
TimC63 is offline
post #7 of 12 (permalink) Old 06-02-2005, 04:09 PM
here are the ratios for the close ratio which is the diesel tranny...you will see the big difference in ratios between the wide and close ratio and then you will see why the gas engine is called the wide ratio...and actually the close ratio 3rd gear is closer to 4th than the wide ratio tranny...on my 94 F350 that i swaped in a 12V cummins i used the NV4500 which has ratios almost identical to the wide ratio ZF and it was great!!! I loved it...the close ratio gearing sucks IMO. You can also see why you can do 90mph in reverse!!! LOL
ZF S5-42 Close Ratio
3.79:1(Reverse), 4.14:1, 2.37:1, 1.42:1, 1:1, 0.77:1
ZF S5-42 Wide Ratio
5.24:1(Reverse), 5.72:1, 2.94:1, 1.61:1, 1:1, 0.76:1
Wifes Ride
ryanp is offline
post #8 of 12 (permalink) Old 06-02-2005, 06:50 PM Thread Starter
Hey ryanp, if you get a chance will you go look at my post in 7.3 engine and drivetrain forum called "ZF5 vs. ZF6" it might be on like page 3 or so. Look at the ratio numbers I was givin there, they are different for the close ratio than what you gave me (yours are higher). Let me know what you think. Thanks.
Brody
post #9 of 12 (permalink) Old 06-02-2005, 10:40 PM
no problem.... the ratios he gave you are for a 95 and newer close ratio ZF....the ZF-S5-42 is what came in the trucks from 87-94ish...then they updated the tranny and renamed it the ZF-S5-47 which had some internal upgrades and different ratios for the close ratio tranny. Probably from the numerous complaints of poor gear ratios in the older ZF. And then when they went to the ZF-6 they changed the ratios once again. Hope that helps.
Wifes Ride
ryanp is offline
post #10 of 12 (permalink) Old 06-02-2005, 11:19 PM Thread Starter
Yep, that helps alot. I appreciate your help. You just made me a smarter man! [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
post #11 of 12 (permalink) Old 06-03-2005, 10:08 AM
My Photos: (32)
So we do have the close ratio boxes. [img]/ubbthreads/images/graemlins/phoney.gif[/img]
Guess that means the gear split could be even worse! [img]/ubbthreads/images/graemlins/frown.gif[/img] [img]/ubbthreads/images/graemlins/blush.gif[/img]
Cowboy350,
I read your post in the SD section. Do you find the shift from 3rd (? or is that 4th) to "direct" on the 6sp an easier transition to make when hauling a heavy load than with your old 5sp?
Good info!
TC
TimC63 is offline
post #12 of 12 (permalink) Old 06-03-2005, 04:10 PM Thread Starter
TC, I haven't pulled a heavy load with the 6 speed yet, well once but it wasn't for very long. So far I have been using the old truck for all the hard work. From what I can tell the transition is a little better though. It's hard getting used to the higher gears.
