2015 Ford Transit 3.2L PowerStroke - Page 2 - Diesel Forum - TheDieselStop.com
Transit Diesel Technical discussion of Ford's new Transit Van powered by a diesel engine.
post #16 of 24 (permalink) Old 06-03-2015, 11:43 PM
van_350sd's Avatar
My Photos: (80)
You can install an Espar heater, it works off the diesel and heats the inside of the van with the engine off. Truckers use them to sleep in the sleeper cabs.
Espar heaters, parts, sales and service
Airtronic D4 13,650 btu Air Heater: Espar Heater Parts, EZ Oil Drain Valves & More Industrial Products by the Lubrication Specialist
http://www.navistarpartsandservice.c...onic_D2_D4.pdf
http://esparofmichigan.com/techsuppo...09%20ESPAR.pdf
2000 E350-Super Duty Ext. Mobile LivingRoom-7.3LPSD
van_350sd is offline
post #17 of 24 (permalink) Old 01-18-2016, 06:39 AM
Yep second winter for my Transit and any temps below zero are a serious problem. Had mine towed last Mnday . So current filter has roughly 1500 miles on it woke this morning to -12 air temp and its clogged . The diesel fuel here in Mn is rated for -40 so I know almost for certain that it's a filter design problem. The only work around I can see is to install a fuel filter warming element for subzero conditions . I drive 300 to 400 as a delivery driver and mpg in winter averages 21.5 and in summer 24.
Transit Man is offline
post #18 of 24 (permalink) Old 01-22-2016, 10:02 PM
Phillippeterson's Avatar
Wife and I are looking at a Winnebago Fuse 23T which comes with a 3.2 diesel. Does this engine have enough power? Would you recommend this engine for a small motorhome?
Phillippeterson is offline
post #19 of 24 (permalink) Old 05-08-2016, 02:39 PM
I have had no problems with the cold
Had a custom-made front cover to keep the engine warm
daxs is offline
post #20 of 24 (permalink) Old 07-07-2016, 12:44 PM
Exclamation DON'T BUY THIS ENGINE
I know this thread is old, but I felt I should warn people wherever possible.
DO NOT BUY THIS ENGINE.
Seriously. Don't.
It has serious power for its size and gets decent mileage, but there is NO support in place for it. Parts are rare. Special tools are all but nonexistent. Technicians have heard of them, but few have laid hands on them yet. And FMC will crawfish on their warranty as fast as they can.
The high pressure fuel pump went out on mine, and destroyed EVERYTHING in the fuel system on its way out. FMC claims that this was caused by water contamination. I never saw a WIF light or warning. Changed the fuel filter the same day this happened and did not see any water in the fuel. Yes, I drained the bowl into a glass jar and inspected it. Now FMC says it's not their fault that water got into the engine when they didn't put a proper water/fuel separator in the fuel system.
This is the 5.4 Triton, the 6.0, and the 6.4 all over again. They are lying, and passing the cost of repairing their defective designs off on the buyers and insurance companies. They don't stand behind their products any more.
RUN. Don't walk.
RUN FROM THIS ENGINE.
And don't stop running until you get past the 6.7 liter, too. It's having a lot of the same problems this one is, and FMC is screwing everyone they can on the cost. This engine is still experimental in the US market, and has next to no support. Go buy something proven. Find something old enough to be exempt from DPF, EGR, and SCR. In fact, you should probably stay clear of the entire Transit line for at least another 5 years. These things are so new to this market that they don't even stock brake pads in half of the dealerships I've been to.
Oh yeah, ALL of the Transit parts are dealer only, except maybe the tires. You'd think you were driving a Mopar the first time you go looking for an air filter.
Learn from my mistake. Stay away from the Transit, and ANYTHING equipped with the 3.2 Puma/Duratorq/Powerstroke.
You've been warned.
8873IDI is offline
post #21 of 24 (permalink) Old 07-07-2016, 03:23 PM Thread Starter
Sorry that things aren't working out for you. 149,000 miles on ours and the only problem we have had with the engine was the EGR cooler and a couple of EGR temp sensors. If the HPFP was a bad design, I would think that we would have seen it in our van by this time.
Parts availability is an issue, but I'm not too surprised. Last time I went down tot he dealer to stock up on fuel filters, they told me that they haven't sold any to anyone but me meaning that there aren almost no Diesel Transits around town.
2, 2007.5 LMM C5500 passenger buses each travelling 100,000 highway miles a year, as of December 2014, each over 700,000 miles.
1, 2006 C5500 passenger bus, with a reman engine at 425,024 miles on 28 Sep 2014.
1, 2013 Freightliner M2 chassis/Cummins 6.7 ISB passenger bus travelling 100000 mountain miles per year.
2, 2010 Ford F650 buses with Cummins engines, each at about 300,000 miles.
1, 2015 Ford Transit 11 passenger wagon with the Powerstroke 5 cyl engine traveling about 125,000 miles per year.
The bane of my existence: A 2006 Sprinter.
And a bunch of stupid minivans.
TDIDog is offline
post #22 of 24 (permalink) Old 07-07-2016, 09:42 PM
It is unfortunate you had an issue with your pump. I have also heard of a few bad dealers trying to get away with voiding warranties so they don't have to work on them. In most cases it was resolved, with the customers coming out ahead, with just a little bit of persistent phone calls to Ford corporate.
You might want to ask the dealer how they came up with the conclusion that the fuel was contaminated and ask if they sent a sample in to have tested or even if they took pictures of the contamination. Chances are they didn't, which would be a good case to bring up to Ford. In fact, you should take a fuel sample yourself and send it in to have tested. The results from the test does hold up better than the dealers word of mouth.
As such, one problem with one part (and a questionable dealership) will not make anyone run away from any diesel. You are correct though about limited support at this time with the transit.
2001 Ford E350 7.3 Extended Cargo Van
BTS Transmission, PHP Minotaur package, 4" exhaust/downpipe, FRX, AIH delete, Fuel bowl mod, Hypermax Boost/Pyro gauge, sloted Frozen Rotors, 4.10 rear w. LS, 350-1200SD front coil springs, Stiff Bilsteins shocks.
Xphobe is offline
post #23 of 24 (permalink) Old 07-08-2016, 05:32 AM
AlH
Originally Posted by TDIDog View Post
I will attach some pictures and a link to my photobucket album. Ask any questions that you want about it and I'll try to answer them.
Hey! Whats the pic of the torn filter right before your EGR pic? http://i1343.photobucket.com/albums/...psf7d474cf.jpg
What is that? Doesn't look like a fuel filter.....
Story behind it?
TIA!
96 F350 CrewCab BTS-E4OD 4.10 4x4 / Banks Git-Kit / 99-Intercooler / 00 FourWheelCamper Pop-up
2015 Transit T350HD 3.2D- totalled- replaced with 2018 Transit T350HD 3.5 GTDI
AlH is offline
post #24 of 24 (permalink) Old 04-20-2017, 10:51 PM Thread Starter
So I was talking with my old boss the other day and he said that the Transit had lost the transmission. I'm guessing about 225,000 miles or so. Cost was $2800 plus installation.
TDIDog is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Transit Diesel
