Bubbles in degassing tank - Diesel Forum - TheDieselStop.com
Transit Diesel Technical discussion of Ford's new Transit Van powered by a diesel engine.
post #1 of 4 (permalink) Old 09-18-2017, 10:32 AM Thread Starter
The Ford dealer said that Ford Motor Company said that bubbles in the degassing bottle is normal. 2016 3.2 Diesel, the Ford dealer said that Ford Motor Companysaid that this is normal.
Under warranty Ford replaced the EGR cooler to correct a coolant issue and the engine because of a gaulded cylinder. If the pressure is released from the cooling system and then ran to operating temperature then sit not running for two
days there will still have pressure in the cooling system.
I do not believe that this is normal, will a Ford 3.2 diesel expert please explain to me how it is normal.
luscsmith is offline
post #2 of 4 (permalink) Old 09-18-2017, 10:32 AM Thread Starter
post #3 of 4 (permalink) Old 09-23-2017, 09:48 PM
The transit I used to take care of popped the. EGR cooler again ( it has 230,00 miles) and after they put the new - updated - one on, they found it is again leaking. They way they know is that when they loosened the clamp on the ERG cooler and coolant ran out.
2, 2007.5 LMM C5500 passenger buses each travelling 100,000 highway miles a year, as of December 2014, each over 700,000 miles.
1, 2006 C5500 passenger bus, with a reman engine at 425,024 miles on 28 Sep 2014.
1, 2013 Freightliner M2 chassis/Cummins 6.7 ISB passenger bus travelling 100000 mountain miles per year.
2, 2010 Ford F650 buses with Cummins engines, each at about 300,000 miles.
1, 2015 Ford Transit 11 passenger wagon with the Powerstroke 5 cyl engine traveling about 125,000 miles per year.
The bane of my existence: A 2006 Sprinter.
And a bunch of stupid minivans.
TDIDog is offline
post #4 of 4 (permalink) Old 09-24-2017, 08:42 PM Thread Starter
The new engine has over 20,000 miles on it now and it has been bubbling the whole time, have you ever heard that this bubbling is normal on this engine?
  Diesel Forum - TheDieselStop.com > Ford Diesels > Transit Diesel
