'97 PS dually can I swap gears to 3.73's ? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 08-15-2018, 05:46 PM Thread Starter
Just bought a 1997 F350 PSD / Automatic super cab dually and it has a 4.10 limited slip rear differential. Since I will not be pulling anything heavier than my 8000 pound 5th wheel I was wondering if it is possible and a good idea to swap in a set of 3.73 gears? I might pull this trailer once or twice a year short distances (less than 500 miles). Other than that it will be pulling cars and light trucks on a car trailer.
I bought the truck because I did not believe it to be a good idea to do the job with my 2002 F150 Supercrew with a 5.4 / automatic / 4x4 with 3.73 limited slip differentials. Correct me if I'm wrong.
Thanks, Andy in KY
1988 F350 CC Dually, 7.3 w/Banks Turbo Charger, 4:10 Gears, 37' fifth wheel, daily driver
MB450SL is offline
post #2 of 5 (permalink) Old 02-26-2019, 12:40 PM
I did on my 96. Went from 4:11 to 3:55. Wish i would of done 3:73 and still may. Ordered new ring and pinion and everything from Youkon. Works great! The rear end is a Sterling 10.25.
1996 F350 CC 2wd Dually. ZF5 swap,DIY Efuel,99 IC, 147k miles OBS Proud!
Bigjake is offline
post #3 of 5 (permalink) Old 02-27-2019, 12:19 AM
What's the weight of the car trailer and how many cars or light trucks does it carry?
DonWarkentin is offline
post #4 of 5 (permalink) Old 02-27-2019, 12:32 AM
klhansen's Avatar
My Photos: (180)
The dually rear axle may be a Dana 80. Most likely not a Sterling (Ford) 10.25. Those were only SRW axles used on F250 & F350.
But that doesn't mean that taller gears wouldn't be available for the OP's truck.
), AIS,
regulated return,
klhansen is offline
post #5 of 5 (permalink) Old 02-27-2019, 07:30 PM
Patrick Feeley's Avatar
My Photos: (19)
F350 Dually axles were Sterling 10.25 (mine was at least). I think the F450 Super Duty OBS may have been the Dana 80. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
