Bosch 0044 Lift Pump - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 09-22-2017, 05:45 PM Thread Starter
Does anyone where online I can find a real Bosch 0044 lift pump? I bought one on ebay for 90$ and it leaks out the negative terminal. I suspect Chinese fake.
ford7.3 is offline
post #2 of 6 (permalink) Old 09-22-2017, 10:12 PM
chuckster57's Avatar
https://www.amazon.com/Bosch-61944-U.../dp/B003WL73OK
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 6 (permalink) Old 09-23-2017, 07:00 AM Thread Starter
I'm a little worried that this is a fake. some of the reviews say it is
ford7.3 is offline
post #4 of 6 (permalink) Old 11-01-2017, 07:22 AM
I purchased mine from Amazon 2 years ago, no problems.
97 F350 XL std cab, zf5, srw (converted), 4wd, 3.55s, stock rims/tires size & rebuild 9.19
2 Donaldsons, 3" dp, ACs & Hydra w/PHP & 1023, DIY 60 gl tank w/6 gl sump, eFuel/Cat filters, T500, HV LPOP, Aeromotive RR, Auber instruments & IDM mod, KC 300X 63/70/84, boost fooler, RiffRaff bellowed up pipes, 6.0 IC & 3" plenums w/RiffRaff inserts & SB 425HD
MeTo is offline
post #5 of 6 (permalink) Old 11-03-2017, 02:57 PM Thread Starter
I ended up buying one from summit racing for 230$, they didn't send any thing with it. the 90$ one I bought from ebay came with hardware extra fitting and even boots to cover terminals. you could not tell the fake from on a first Glace. but it was obvious that all maeking on the pumps where in different fonts, and the real pimp came with bosch paperwork. the fake did work, but just spend the extra money
ford7.3 is offline
post #6 of 6 (permalink) Old 01-04-2019, 07:00 AM Thread Starter
My Bosch 044 failed me agian. The only thing that ever let me down on this truck. A local guy, who started a business installing his own fuel systems on powerstrokes, told me that with a large pump like that, It will continue to fail if I use dual tanks. Something about the selector vavle screws with the pump. He recommended a super duty pump which is a smaller Bosch pump but should support my 160s. This pump is supposed to be more reliable, I've been running it for a few weeks and no problems yet. I firgued I'd share this information maybe it will help someone esle.
ford7.3 is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
