Bought a rebuilt US Gear Over/under drive - Diesel Forum - TheDieselStop.com
post #1 of 1 (permalink) Old 04-29-2019, 11:48 PM Thread Starter
I found a rebuilt unit & it’s being shipped. Also ordered the 4x4 adapter since it’s needed to adapt it to a 2wd E4OD. I have the Dana 80 4.10 lsd dually so should be a really nice od on the hwy.
I only want to use the overdrive & direct drive. It does not include any electronics. I found an online operators manual for it for the controller & switch that I don’t have. There is no schematic that I could find.
It looks like I don’t really need the sensors hooked up which just go to leds that show a status of the unit. Also the controller is just momentary switches which turn on power to run the motor which loads the spring.
There are 2 power connectors but I don’t see a ground connector, so my question is- when the switches are pressed is the polarity on the 2 power connectors reversed OR is the case grounded & when a button is pressed is power supplied to 1 connector & when the other is pressed is power applied to the other connector?
mdshaw is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Similar Threads
turbo vs gear vendors under/over drive Darryl97420 6.9L IDI Diesels (Not Power Strokes) 14 09-20-2014 12:31 AM
Gear break in and differential basics by Nitro Gear and Axle Just Diffs Wheels, Tires, Brakes, and Suspension 0 12-30-2012 06:34 PM
Rebuilt 4R100, no 3rd gear (or OD) bOOmerF350 '99 & up 7.3L Power Stroke Engine and Drivetrain 1 05-19-2011 08:18 PM
Disassembling 99 manual transmission VTKerr '99 & up 7.3L Power Stroke Engine and Drivetrain 1 01-21-2010 10:40 AM
Bought a truck with gear vendors and turbo!!! jrfastbanshee 6.9L IDI Diesels (Not Power Strokes) 7 03-03-2005 04:19 PM
