CEL when using chip - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 09-01-2019, 07:12 PM Thread Starter
CEL when using chip
Hello,
I have a 94 f350 that has full force stage 1 injectors and a hydra with the tunes that full force provided for their injectors. When I have the hydra on the stock setting, I never get a CEL but also donít get to take advantage of the extra power. I have has the same tuner and injectors in the truck for about 2 years now and have had this problem the entire time. I installed them together.
When I try to use any setting other than stock I usually get a check engine light. I have not been able to get any stored codes and turning it off and back on makes the CEL go off. While it is on, the engine sounds funny at an idle. It cackles, if that makes sense. It also seems like the throttle pedal has a delay, and is very sensitive. At speed you donít notice much of a difference in the way it runs. There have been occasions where I can drive it for hours with the chip on before getting a CEL. Other times it is less than a minute.
I am guessing that I may have another component on the motor that it wore out and canít keep up with the larger injectors and the chip, but I have no idea where to start troubleshoot.
It also has a new fuel pump and a reman hpop that have been on the truck prior to the injector change. Any ideas would be appreciated
tx4wheeler71 is offline
post #2 of 3 (permalink) Old 09-01-2019, 09:34 PM
Patrick Feeley's Avatar
My Photos: (19)
What are you using to try and pull codes? Have you been successful using it on this truck before? Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3Ē DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #3 of 3 (permalink) Old 09-02-2019, 02:36 PM Thread Starter
I am using a innova 3145 Ford ODB1 scanner. Never tried a code reader on my truck before this since it had never had a CEL before.
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
