Double-DIN radio? - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 11-19-2018, 09:32 PM Thread Starter
Steve83's Avatar
Double-DIN radio?
A friend sent me this - it looks like a well-made part (or kit?), but I don't have an Instagram or FB account, so I can't read everything:
https://www.facebook.com/pg/obsinteriors/about/
Steve83 is offline
post #2 of 4 (permalink) Old 11-20-2018, 09:40 PM
bugman's Avatar
My Photos: (12)
Looks like it would be a nice kit but $300 for the trim and then what ever the radio cost you would really want that type of upgrade.
bugman is offline
post #3 of 4 (permalink) Old 11-20-2018, 10:08 PM
79jasper's Avatar
Does open up options.
Android head unit running torque.....
Sent from my SM-N960U using Tapatalk
79jasper is offline
post #4 of 4 (permalink) Old 11-21-2018, 09:36 AM Thread Starter
Steve83's Avatar
I e-mailed him and got some info.
Originally Posted by me
Is this just a single part, or a kit of several pieces to modify the dash for a larger radio? What is included, at what total price (shipped to 38060), and how long is the wait? Does the bezel come color-matched (mocha), or do I have to paint it? Is it hard plastic, or padded foam? What I'm really curious about is how much of the dash has to be cut away (because I have other plans in this vicinity), and how the radio will mount afterward (so I can choose a radio that will fit well). I'd also like to read the PDF instructions.
Originally Posted by OBS Interiors
-the bezel itself is a molded piece of abs plastic
-they come color matched for a stock interior color
-a bezel alone costs $160 shipped
-a full kit includes a bezel, a new pad, a new trim piece that's below pad, template to make 2 radio holding brackets, and pdf file instructions that have pictures. I only send out the instructions once the order has been made.
What needs to be cut is the cross piece separating the radio hole and hvac hole. Then there's a metal bracket up under the top of radio hole that's gotta go. Then shave maybe 8th inch off the top pf radio hole and you're done
- price on that ful kit is $300 shipped
-i offer cores on pads and the long trim below it
$50 for a pad. $20 for the trim
There is a down payment of $100 if you order.
-there's no current website just a facebook page called obs interiors. Here's a link just in case you do have facebook
https://www.facebook.com/obsinteriors/
-the pads in the kit have been cut to size, stripped the original vinyl off and repaired any foam that's damaged, then they get wrapped in marine grade vinyl leather. I choose that type because marine grade is uv resistant and handles temps well.
-the trim piece gets a section removed and plastic welded back together
-since i am a 1 man operation with a normal job that's 50+ hours a week and a wife at home so i have home duties as well. This makes wait times kind of tough. Currently as of right now i have a ton of orders and the wait ETA is May.
Steve83 is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
