LinkBack | Thread Tools | Display Modes |
Help with LJP1 pcm tuning
Hi I just joined up. I have a very unique powerstroke. It started life in 1997 as an unfinished E350 dually ambulance chassis. It then got an extended cab & a full aluminum service bed with aluminum service boxes on each side of the bed. It was built this way to be able to haul jet helicopter engines & still be light weight. I'll be using it for hauling my 5th wheel car trailer. So now yes it also has a 5th wheel hitch. The frame rails already had the factory mount holes. Maybe the only E350 with a 5th wheel hitch.
In the last few weeks I've relocated the batteries to the tool boxes, installed a 6637 air filter, removed the mechanical fuel pump, installed an electric fuel pump with dual filters which are in another box, built a 2 stage 8 gallon methanol/water injection system. Today replacing the water pump since it's dripping. Also later this week pulling the transmission for a rebuild/upgrade along with a Revmax TC. Also installed a Suburban back seat in the extended cab for our son.
I just pulled out the injectors this morning & sent them to Rosewood & want to upgrade the AB's to single shot 180/80's. I ordered the TS tuner & was told the TS does not support the LJP1 Super Duty E350 pcm. I wanted to send the chip to Tony Wildman for some nice tunes. So I really need to figure something out before they get to Rosewood.
What do I do now? Different tuner, different pcm? Anyone have any ideas? I can repin for a different pcm if necessary. I sent Tony an email about it also.
Sponsored Links | |||
Advertisement |
As a follow up - Rosewood suggested that I contact Brian Jelich -proprietor of JeliBuilt Performance. He looked up the pcm & code. He says he can build tunes for but suggested the Hydra tuner & has been very helpful.
Advertisement |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
PCM xle4 Tuning | Terryk | '99 & up Upgrades and Aftermarket - 7.3L Engine | 14 | 01-30-2019 09:08 PM |
Won't Start | rocinbaja | '99 & up 7.3L Power Stroke Engine and Drivetrain | 23 | 12-21-2012 09:32 AM |
Truck just died, running fine, then started sputtering, then would not start. | Thumper723 | '99 & up 7.3L Power Stroke Engine and Drivetrain | 116 | 09-02-2007 01:34 PM |
P1670 and P1678 IDM? | Beast | '99 & up 7.3L Power Stroke Engine and Drivetrain | 2 | 09-02-2007 01:30 PM |
A Better PCM | CharlieII | '99 & up Upgrades and Aftermarket - 7.3L Engine | 2 | 06-30-2005 01:14 PM |
Posting Rules | |
