If you had 2,200 dollars to spend on injectors - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 02-26-2019, 05:23 PM Thread Starter
Ok, Wife said i could have the tax money for my truck!!! "shes a good wife!" $2,200 to spend!
Im looking at a set of baby swamps with tuning, but im trying to decide what to choose between an Adrenaline HPOP or a DIY D66 turbo kit from Barder Turbo.
My truck specs are:
1996 F-350 CC Dually 7.3 144,000 miles
E-Fuel
99 inter cooler
ZF5 Swap 2wd
Tymar intake
3 inch DP to 4 inch straight exhaust
What would you guys do? My HPOP and Turbo are stock as of now. No problems with either.
I dont want to be fighting EGT issues "i already have gauges" but i dont wanna run short of HPO either!
More air or more oil. That is the question i guess!
Thanks, Jake
1996 F350 CC 2wd Dually. ZF5 swap,DIY Efuel,99 IC, 147k miles OBS Proud!
Bigjake is offline
post #2 of 4 (permalink) Old 02-28-2019, 10:39 AM
RT
RT's Avatar
I think your HPOP has a 15 degree swashplate since itís an OBS. Upgrading to the 17 degree will probably give you the most bang for the buck right now.
https://deadheaddiesel.com/7.3-powerstroke-hpop/
As to the injectors, I would recommend Stage 1.5s from Full Force. You can get them with the appropriate tuning at DP-Tuner. You could send your PCM in for a reburn while you are doing the injector swap. Make SURE and get a linear pedal tune as the regular tune is jumpy with a standard transmission. You really donít need multiple tunes since the biggest difference in them is when the auto tranny shifts.
RT is offline
post #3 of 4 (permalink) Old 04-22-2019, 11:10 AM
narmalee's Avatar
For 2200 go with hybrids, you are right on the door for them and more room to grow with the same amount of oil.
-'97 F250HD 4x4 7.3-
-'99 Cobra 426w-
-'76 LS408 Stingray-
-'93 302 Camaro on the juice-
narmalee is offline
post #4 of 4 (permalink) Old 05-07-2019, 11:45 AM
My Photos: (42)
If you have to choose btwn HPOP & D66, do the HPOP and get the smaller "Van" turbine housing (1.0A/R) instead of the D66. The Housing is usually less than $180 shipped and makes a big improvement.
I did Unlimited Diesel 30%, Gearhead tune, Adrenaline HPOP, and the smaller Housing about a year ago. Now it makes 25psi with an ATS intercooler and I'm happy how it runs.
Look at what KC Turbo offers as well.
AggieDiesel'01
'91 F250 4x4 XLT Lariat ext. cab ZF 5 speed, Ramsey 12k winch, Add-a-leaf in front, Ford Factory/ATS Upgraded Wastgated Turbo (installed @ 252k), 3.5in Hypermax Exhaust (Turbo whistle is awesome) 330,000 miles and counting. Recently cosmetically restored inside and out and now lives on with my dad.
'97 F250 4x4 XLT CCSB Last of the good ones, 88,000 and counting. Not much done yet, came with gauges, programmer and ATS Intercooler, now has UDP30 AD injectors, Adrenaline HPOP, 1.0A/R Exhaust Housing, GearHead Tunes.
AggieDiesel01 is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Similar Threads
Can EGR Cooler/Head Gasket Failure kill all 8 Injectors? apoth 6.0L Power Stroke Engine and Drivetrain 21 02-19-2011 03:15 AM
How could I have injectors tested periodically to warn of trouble? mwe-maxxowner '99 & up 7.3L Power Stroke Engine and Drivetrain 1 07-16-2010 01:32 AM
bigger 7.3 injectors powerstroke73314 '99 & up Upgrades and Aftermarket - 7.3L Engine 7 01-28-2010 12:40 AM
Fuel Injectors Leaking - PLEASE HELP! Gaeliknight 7.3L IDI Diesels (Not Power Strokes) 13 04-08-2006 11:49 AM
Replaced the injectors (finally) - thoughts on the importance of the copper washer jaluhn 6.9L IDI Diesels (Not Power Strokes) 28 03-13-2005 07:46 PM
