New Source for International Water Pump - NAPA - Diesel Forum - TheDieselStop.com
post #1 of 19 (permalink) Old 04-18-2008, 03:44 PM Thread Starter
I've been looking into upgrading my water pump to the International version with the built in coolant filter header and have found an alternative source for the pump besides Navistar. A company called Haldex sells the same pump in both new and reman form. The great news is the price. I just ordered a new pump from NAPA for $200 plus shipping. This is almost the same price as the standard Powerstroke pump. Plus there is no core charge or need to return the old one when buying the new version. For some reason the reman pump actually cost about $40 more than the new one and requires a core charge or returned pump. Unfortunately, Haldex does not sell direct and my Napa parts guy really struggled to get it since they don't normally sell it. Napa is a Haldex dealer though and should be able to get it. I ended up calling Haldex myself and then gave Napa the contact info for the person I was dealing with. A place called FleetPride could get it as well and for a little less money even.
Haldex catalog download
Haldex catalog page
Haldex part numbers -
New - RW6114
Reman - RW4114X
Shawn
96 Roll-A-Long F-350 4x4 Crew: 110,000 miles, built E4OD, 1.0 housing, and 3"x4" down pipe.
AZStang is offline
post #2 of 19 (permalink) Old 04-18-2008, 07:15 PM
Very good find! I called my local HD parts distributor, they have the reman in stock for $225 but no new.
By the way, Haldex is Midland who have been in the HD reman parts business for years. Generally good quality.
Diesel Mechanic 34 yrs Maintenece Manager 23 yrs
Garbage_Mechanic is offline
post #3 of 19 (permalink) Old 04-18-2008, 10:18 PM
S95
is the "new" pump made in china? the reman a remaned OE ?
1995 F-250 PSD 4X4 EXTRACAB LONG BOX AUTO
TYMAR FILTER, 4" MBRP STAINLESS TURBO TO TAIL
EOT MOD FOR COLD STARTS
CUSTOM RUNNING BOARDS
SD STARTER
STANDENS FULL 3 LEAF FRONT SPRINGS
1990 25th Anniversary 5.0 GT
2012 F150 4X4 supercab longbox HDPKG 5.0
S95 is offline
post #4 of 19 (permalink) Old 04-19-2008, 10:34 AM Thread Starter
That's the same problem I had. I found the part numbers first and then called local distributors, nobody could find the number for the new pump. That's when I called Haldex. The person I talked to verified the part number and availability and told me to have Napa call him directly. The other retailers I talked to had to call in to get price and availability as well.
It was during another call I made to Haldex that I learned they manufacture the reman pump and buy the new pump from someone else. He asked my why I didn't want a reman. He was a little surprised when I told him the new pump was cheaper than his reman. But the big benefit of the new pump for me was there is no need for a core.
That's a very good question that I didn't think to ask. I will find out. Both pumps do carry the same 1 year warranty though.
Shawn
AZStang is offline
post #5 of 19 (permalink) Old 04-20-2008, 06:06 PM
JMCX's Avatar
Our water pump has the lower rad hose water neck on the drivers side. Make sure you order the Ford Powerstroke version and not one for a school bus.
97 F350 SW CC 4X4 Auto, IDM mod, TW six position, DIY Stage I's, Beans D66 Turbo & 3" DP, 4" straight exhaust, Mobil 1 ATF, Tru-Cool 28k, Fuel filler mod, 99 Intercooler, Open Air Filter, SmittyBuilt stainless nerf bars, Trans-go tugger kit and Billet TC
2011 Silverado LML (work truck), 72 Mach I 552 stroker
JMCX is offline
post #6 of 19 (permalink) Old 04-21-2008, 09:26 AM Thread Starter
It is the school bus version of the pump with the built in coolant header. The full story can be found Here.
I called Haldex this morning to ask where the New pump is made. He didn't know for sure, but thought it was probably an import. Though he didn't know from where.
I'm not sure how big a deal that is as I've never asked where any of the water pumps (or other parts for that matter) that I've purchased over the years were made. Something to consider though.
Shawn
AZStang is offline
post #7 of 19 (permalink) Old 05-16-2008, 01:00 PM Thread Starter
I picked up my New Navistar water pump this week. It looks pretty sweet. I also have figured out that a Wisconsin company called Geomar makes it. I called them and was told the pump is assembled in the US. I believe the machined casting is probably what they import. They don't sell direct, but will give you a list of places to buy it. Might even be able to get it cheaper by eliminating Haldex from the chain.
Geomar Heavy Duty
Shawn
AZStang is offline
post #8 of 19 (permalink) Old 11-28-2011, 05:58 PM Thread Starter
Figured I'd follow this up with the death of my Geomar pump since it died last week. 3.5 years and 30,000 miles. The bearing went quick too once it started leaking. The price for a new one at the International dealer was only $215, so that's what I replaced it with. Hopefully it will last longer than the Geomar.
Shawn
AZStang is offline
post #9 of 19 (permalink) Old 11-28-2011, 10:11 PM
Wow! I think I have about 200,000 more miles than that on my stock one! In general this is a trend I've noticed with water pumps on L10 and M11 Cummins as well a several others, water pumps living about 1 yr or 2,000 hours. (We don't track miles so much since we only average 15mph) I hope you get more than 30,000 on your IH one. Let us know!
post #10 of 19 (permalink) Old 12-15-2011, 07:26 PM
I just picked up my International pump from Absolute Bus Sales for $200 and they offer a 1 year/100k mile warranty on it. Hopefully it doesn't fail in short order too, or if it does before the warranty end of course.
International T444E Water Pump Sales, 1831676C92, 1889249C91
'94.5, 5spd, 204k miles, Swamps Babies-tunes-IDM, Adrenaline HPOP & late IPR, IH Waterpump, S&B airbox, 3" DP & 4" Magnaflow exhaust, IH bellowed up-pipes, WW2, non-EBPV ped, Beans fuel, 6.0L Intercooler & Banks pipes, CCV Mod, ZF5 S547 & SB OFE, 3.55's & Truetrac diff, rear discs, Bilstiens, Redhead SB & Borgeson intermediate, A proud Texan 2WD XL!
preith is offline
post #11 of 19 (permalink) Old 12-15-2011, 10:25 PM
Patrick Feeley's Avatar
My Photos: (19)
If you figure out how to do a clean install on an early PSD (94-95), post up how you did it (bottom hose on radiator is on the opposite side than the later ones) as I've never seen anyone do it. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #12 of 19 (permalink) Old 12-16-2011, 01:56 AM
Hi Patrick, I was the guy who posted on the 94-95 thread concerning this too. The project of course snowballed into other stuff, the intercooler for staarters, but I'll finally be doing that this weekend. It will be 3 pieces with couplers so I don't know how "clean" it can be, but I'll upload a few picks regardless.
preith is offline
post #13 of 19 (permalink) Old 12-16-2011, 12:05 PM
My factory WP on my '96 PSD was replaced due to leaking @ 138,000 miles. I went with a Ford reman at the time. I remember the parts manager said they had a bad batch of reman's and 3 out of four leaked after install. I was real happy about that but 10-12 yrs later & 160,000+ miles it's still just weeping, not enough to replace yet.
I had a bad situation 25 yrs ago on a Ford 300-6 where I'd have to replace a leaking water pump every year & about 8000-10,000 miles. The "FREE Replacement" still ended up costing me big bucks for the new antifreeze every year. I was told years ago that the cheap rebuilds use a very cheap material on their face seal to keep antifreeze away from the bearing. The OEM and good pumps use Ceramic face seals, most of which were made at the time by a division of a famous brewing company located in Golden CO.
I've often found that trying to save a few bucks on "CHEAP" repair parts ends up costing a LOT of extra money, and probably moreso on waterpumps than anything else.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline
post #14 of 19 (permalink) Old 12-18-2011, 03:46 PM
CrescentGutter's Avatar
Could this pump have worked?
I ask because my '97 also has the lower hose outlet on the driver side. I have no problem currently, just for future reference.
Todd
1997 F Super Duty XL DRW. 7.3 PSD, automatic, DP Tuner F5 4 Position Chip, Diamond Eye 3" down pipe, K&N hardware/NAPA 6637 filter intake, Riffraff intake boot.
Altec AT 200A boom/bucket, custom built flatbed.
My other diesel: 2008 Bobcat S185.
CrescentGutter is offline
post #15 of 19 (permalink) Old 12-29-2011, 12:33 PM
DavidD's Avatar
Not to hijack this thread but what do you use your boom for?
93 F-250 7.3L XLT Extended cab 2wd 235K Auto.
95 F-250 PSD XLT 4X4 E4OD Tony wildman 6pos chip, Custom intake,pillar Gauges
89 F-350 7.5L 5spd Dump
96 F-350 PSD 5 spd Dump
99 F-350 PSD 5 Spd Dump
96 IH 4700 DT466 7Spd Dump
2002 Isuzu NQR Dump was a box until I solved that problem.
DavidD is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
