TDEI TS6 pos chip on a NAW4 PCM? - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 10-19-2018, 08:15 PM Thread Starter
I have a 1996 auto trans. The chip I ordered came in for a TDEI pcm. But when I pulled my pcm it's a NAW4.
Can I still use the ts 6 pos chip on my pcm?
I apologize if this has been covered.
Thanks in advance!
Andrew.
Ajdusmc is offline
post #2 of 3 (permalink) Old 10-21-2018, 06:41 AM
I'd ask the people you bought the chip from.
AaronSEIA
My Truck:
97 F250 4 door shortbed, E4OD
DIY intake
Kingpin Dana 60
otherwise stock
AaronSEIA is offline
post #3 of 3 (permalink) Old 12-07-2018, 06:24 PM
spazzyt5's Avatar
Did you ever find out your answer? I’m curious cause I bought a used TS6 chip and the guy said he had it on a NAW pcm and I have both NAW and TDE1 on hand and am getting a no start with both. Was curious what you found out.
1997 F350 CCLB SRW 7.3 Centurion Edition
. ALL STOCK 132,204 (as of 8-18-16)!!!
'97 F-350 CC LB SRW 7.3L -
Stancor GPR, High Torque Starter from DB, Upgraded Battery Cables, Diamond Eye 4inch Turbo back straight piped exhaust. - SOLD
'03 F-250 CC SB SRW 6.0L - SOLD
*New to the diesel world, researching everything i can and learning how to do the work myself.
spazzyt5 is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
