Trying to delete my tanks and run an in bed tank - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 03-26-2019, 02:13 PM Thread Starter
Does anyone have a shopping list on how to do this? I’m tired of the leaky tanks that ford uses and just want to put one 100gal tank in the bed and be done. I pull my camper a lot with this truck so that’s why I’m leaning towards the 100gal
Markley55 is offline
post #2 of 5 (permalink) Old 03-28-2019, 08:43 AM
tbeck's Avatar
It can be done, but I'd be leery of it if you're in a state where inspections are required. It'd probably be an issue. I feel bad for guys in the "rust belt"; I've never had to replace a fuel tank or straps that failed, and only an occasional muffler.
'94 1/2 F250 4x4, SuperCab XLT, 5 spd, SMF w/ Valaeo clutch, 4.10 (syn. lube), Rotella 5W40 Syn, manual hubs, B&W Gooseneck hitch, Cooper ST Maxx tires in 235/85R16, authentic TYMAR intake, 4" AFE exhaust, FRP mod., SD starter, Isspro boost/pyro,digital thermometer, homebuilt exhaust brake, 194K Fresh factory injectors at 186K, TS-6 chip. Dana 60 conversion! "Its only a pickup. Trucks have a button on the shifter!"
'12 F150 Supercrew, 4x4, 5.0L, Lariat, 146K, "Race Red" and no speeding tickets yet...
1996 Bronco, last of the line! XLT, 5.8L, 160K and going strong!
tbeck is offline
post #3 of 5 (permalink) Old 03-29-2019, 12:41 PM Thread Starter
There are zero inspections on our vehicles in Iowa. Would it be as easy and a tank, fuel pump rated for out lift pumps which is 35gph at like 60psi, and plumbing a return line. Adding a filter obviously on the pressure side.
post #4 of 5 (permalink) Old 03-30-2019, 10:31 AM
I don't see any big problems with replacing the factory tanks with big fuel tank in the bed. With the new in-bed tank, you could remove the truck's fuel tank selector valve and just run a fuel hose from the bottom of the new tank and connect it to the fuel line that the selector valve was connected to. Also, you would need to run the return-fuel line to the top of the new tank with a proper fitting. If you want to monitor the fuel level in your tank, you would need to rig-up a fuel level float and sender system in the tank and a gauge in the cabin since the factory equipment obviously wouldn't fit the new tank.
I have a 91-gallon RDS aluminum fuel tank in the bed of my F250 that I use with a pump and a fueling nozzle to fuel the truck's factory fuel tanks as well as other diesel equipment. The tank has ports at the top and the bottom that could accommodate its use as the truck's only tank by doing what I described above.
MichaelPatrick is offline
post #5 of 5 (permalink) Old 04-04-2019, 06:11 PM
I removed the entire stock fuel system and went to a custom 66 gallon tank with efuel and a regulated return. It works great and takes the big nozzle too. I had the tank fabed to utilize the stock fuel sender. It works great.
97 F350 XL std cab, zf5, srw (converted), 4wd, 3.55s, stock rims/tires & rebuilt 9.19
2 Donaldsons, 3" dp, ACs & Hydra w/PHP & 1023, DIY 60 gl tank w/6 gl sump, eFuel/Cat filters, T500, HV LPOP, Aeromotive RR, Auber instruments & IDM mod, KC S300 63/70/84, boost fooler, RiffRaff bellowed up pipes, 6.0 IC & 3" plenums w/RiffRaff inserts & SB 425HD
MeTo is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Strokes 1994-1997 Upgrades and Aftermarket
Similar Threads
Trick to filling the fuel tanks? xj4rocks Power Strokes 1994-1997 General 8 08-27-2006 10:13 AM
How to drop the tank? mtnbkr132 1999-2007 General Questions 3 01-03-2006 04:48 PM
Rear fuel tank float stuck??? a_robertta Power Strokes 1994-1997 General 7 09-23-2005 10:12 AM
filler vent mod fastford Power Strokes 1994-1997 Upgrades and Aftermarket 1 08-19-2005 03:10 PM
Can't fill up unless I hold the fuelhandle just right-what a pain! PreservedSwine Power Strokes 1994-1997 General 24 05-16-2005 01:55 PM
