'1990 7.3L IDI Turbo fuel filter change won't start - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 05-06-2018, 01:32 PM Thread Starter
I remove fuel filter to add sea breeze field fuel filter to the top with sea breeze lubed the Rubber seal installed the fuel filter hand tight turn down the motor it started up right away ran for a few hours when I try to turn it back on it would turn on for at least a couple of minutes then die I want a head and released Air from the housing of the fuel filter connection there was air coming out kind of scratching my head what else could be going on any help would help thank you
steves7.31990f250 is offline
post #2 of 3 (permalink) Old 05-06-2018, 01:54 PM
genscripter's Avatar
Just to start off, try some of the things in this article first, to rule major stuff out: What to do if no Diesel Fuel is coming out of the Schroeder Valve on a 6.9 / 7.3 IDI ? IDI Online
But assuming you had air in your fuel system up to the IP (you said you bled some air), then you might have air in the injector lines. Try this: How to Crack Injector Lines and Purge Air on a 6.9 / 7.3 IDI Diesel Engine ? IDI Online
Also, what is the voltage of your batteries with the key off?
genscripter is offline
post #3 of 3 (permalink) Old 05-11-2018, 12:33 PM
Does your truck still have the two piece fuel filter? It is possible that it wasn't tight enough, or otherwise leaking and allowed the filter to drain.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
