'1990 7.3L Turbo diesel E4OD flashing OD light - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 12-05-2018, 03:25 PM Thread Starter
I have a 90 E350 with a 7.3 turbo diesel and an E4OD. I believe it has 167,000 miles, came from the state with records and appears to have had regular maintenance. No maintenance listed on transmission other then fluid level checks. The OD light flashes almost as soon as you start driving. The switch is mounted on the dash not on the end of the shifter. Transmission shifts smooth through all 4 gears so its NOT in limp mode. Fluid is full and not burnt. You can turn OD off and on and see the change in RPM. Having problems pulling a code, either no code or failure to read. So looking to see if anyone has ran into this issue.
sarhuey212 is offline
post #2 of 2 (permalink) Old 12-05-2018, 04:28 PM
Mark Kovalsky's Avatar
My Photos: (6)
It never reports no code. There is ALWAYS a code, even if it is a code 11, which is no problems found. You're going to have to fix the problem that is keeping you from reading codes first, then we can find out what's wrong with the transmission.
Are you using this method? https://www.troublecodes.net/ford/
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
