Hello all.
Im having issues with my f250. First i was having issues with the od light flashing intermittently and when i ran the code it said needed to replace the vss. So i did and reset the system. The same thing started happening again along with the speedometer fluxuating when i got over 50mph. So i ran the codes again and said there was a bad tps. So i replaced that and reset the system again. Now it's still doing the same thing and gives me the codes to replace the vss and tps, but this time it gave me code 63 which is either tp circuit fault or fuel injection pump lever sensor input is less than self test minimum. Any ideas or recommendations? Also the tans shifts hard when the od light flashes and im only getting about 150 miles per tank. Normally it was about 250 miles per tank.
