1993 f350 to f550 rear springs? - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 05-03-2019, 09:30 AM Thread Starter
I have a 1993 f350 with 5" lift and would like to replace the rear springs to f550 for my fifth wheel. Does anyone have any knowledge of what year 550 springs will fit? Should I look for new springs with 5" lift and get rid of the blocks?
Alin Dragulin is offline
post #2 of 2 (permalink) Old 05-03-2019, 11:59 AM
Several things to consider. Do you have the bed clearance for the 5th wheel with the lift? Adding airbags may be a better/simpler way to go, you can lower/raise the pressure as needed making for a smoother ride and keep headlights aligned. I got rid of my blocks and set the springs on the axle. Pinion angle is the thing to worry about, but should not be an issue if you are doing well with current lift.
DENNY
DENNY is offline
Similar Threads
Motorcraft Premium Gold antifreeze Foy '99 & up 7.3L Power Stroke Engine and Drivetrain 5 06-05-2009 05:33 PM
Which springs..help retodd Towing and Hauling 17 03-26-2006 12:30 AM
Big Ford Fuel-Related Part Numbers Post DaveBey Power Strokes 1994-1997 General 4 12-07-2005 01:06 PM
VIN for finding out Truck Details? rjarvis 1999-2007 General Questions 6 07-06-2005 07:37 PM
Question for those that have used F350 springs on the rear GregW Power Stroke Excursions 3 05-16-2005 06:11 PM
