3 fuel filters in two months - Diesel Forum - TheDieselStop.com
post #1 of 19 (permalink) Old 08-03-2019, 05:18 PM Thread Starter
Fuel light comes on when going 60 mph with a brand new filter. Fuel that came out of the 1 day old filter is looking pretty bad.
Prof is offline
post #2 of 19 (permalink) Old 08-03-2019, 06:16 PM Thread Starter
The 1994 F350 crew cab dually only has 22,786 miles. I use Power Service additives including a ounce of Bio Clean. I think the fuel sat in the tanks too long.
Prof is offline
post #3 of 19 (permalink) Old 08-03-2019, 09:01 PM Thread Starter
Drove a 1/4 tank out of front tank. Fuel filter light would come on with part throttle load. Came home took filter off and drained it into a mason jar. Same brown mess. Sludge appeared in the bottom of filter. I installed a new Wix filter with no water senso. 3/4 filled new filter with Diesel Kleen like i did with the last three filters. This time the dash lit up like Xmas tree with water in fuel light going off. No fuel, no start. I am getting tired of this. Next stop is probably a flat bed ride to a repair garage.
Prof is offline
post #4 of 19 (permalink) Old 08-03-2019, 09:38 PM Thread Starter
24 views and nobody replied. Anybody have any ideas?
Prof is offline
post #5 of 19 (permalink) Old 08-03-2019, 11:33 PM Thread Starter
Update
Went back and tried cycling the ignition key three times and cranking it over with the gas pedal to the floor. 2nd attempt and it started. This Wix filter has no sensor. The engine idles perfectly. Front tank is at 3/8 full. I want to get it as empty as possible to get the bad fuel out of the tank as much as possible.
I was thinking about running it out of fuel than putting in 5 gallons of fresh fuel. What do you think? Any ideas on getting the tank purged that have worked for you?
Bill
Prof is offline
post #6 of 19 (permalink) Old 08-04-2019, 12:27 AM
bugman's Avatar
My Photos: (12)
Just to give you a answer, get that fuel out of the tanks.
Get a few 5 gallon fuel cans and siphon it out, then put some fresh fuel into it.
You could even get a electric fuel pump and put it on the line from the tank to suck that stuff out.
bugman is offline
post #7 of 19 (permalink) Old 08-04-2019, 09:27 AM Thread Starter
Yeah, the fuel is pretty bad. See the mason jar of bad fuel. i Have a defuel pump from my old race car days, several fuel cans and A deep cycle marine battery.
Where is simple place to tap into the fuel system?
Prof is offline
post #8 of 19 (permalink) Old 08-04-2019, 09:40 AM Thread Starter
How about cutting the fuel line and pulling out the fuel from the line after the lift pump?
Prof is offline
post #9 of 19 (permalink) Old 08-04-2019, 09:48 AM
My Photos: (27)
It's obvious you need to remove the tanks and have them cleaned. We ran into that on rare occasion and pulled the tank, took it over to the steam rack and stuck the steam cleaner nozzle in the tank inlet and let it run for an hour or two.
LMJD is offline
post #10 of 19 (permalink) Old 08-04-2019, 10:53 AM Thread Starter
Ok, thanks. Now I need to find a repair shop that will drop the tanks and clean them.
I am near Ann Arbor, Michigan.
Bill
Prof is offline
post #11 of 19 (permalink) Old 08-04-2019, 02:12 PM
bugman's Avatar
My Photos: (12)
If anything pull at least one of the tanks and just take it to the car wash and clean it inside. Then make sure that it is dry before reinstalling it. Perhaps start with the rear tank since it is a little bit smaller than the front.
As for a shop, go down to a large truck stop or big truck shop in your area. If they won't drop the tank for you perhaps they will clean it if you pull it off.
bugman is offline
post #12 of 19 (permalink) Old 08-04-2019, 04:03 PM Thread Starter
Pumped 20 gallons of fuel from both tanks
My race defueling rig was pressed into service and I fed a five foot piece of tygon into the tanks. After defueling i put in 12 gallons of fresh diesel fuel and I added Diesel Kleen to the front tank. Engine start easily and idles at 750 rpm in gear. Drives well. A new Wix fuel filter and separator. No moisture sensor. The threads were bad on the new filter where the stock water sensor would go.
In addition, I ordered a Wix inline diesel fuel filter to use as a prefilter for the stock fuel / water separator. I want to see the diesel fuel going to the engine.
Bill
Prof is offline
post #13 of 19 (permalink) Old 08-04-2019, 06:49 PM
You'll be replacing the injector pump next. That sh*t is going to score everything in that pump that there is to score. Never mess with dirty fuel. All it is good for now is lighting a brush pile. Clean those tanks out before you run it very long, because the filter (no matter how good it is) can't stop all of the trash coming to it.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #14 of 19 (permalink) Old 08-04-2019, 08:58 PM Thread Starter
Will find a source tomorrow.
Is this the pump?
Prof is offline
post #15 of 19 (permalink) Old 08-04-2019, 09:34 PM Thread Starter
Or is it this pump?
Is this the pump?
Prof is offline
