7.3 IDI engine with 5 bent push rods on one side? - Page 2 - Diesel Forum - TheDieselStop.com
 1Likes
post #16 of 25 (permalink) Old 05-14-2015, 02:24 PM
Are you certain none of the 7.3 idi engines had no chain? Reason I ask, is that Chiltons seems to indicate, without actually sayin, that ther is a chain. The way this engine died and its erratic compression when turned over now, are charachteristic of a broken chain. Gears almost never go. Engine close to 200k
91 oregon is offline
post #17 of 25 (permalink) Old 05-14-2015, 02:59 PM
My Photos: (27)
Right, and that's why diesels have gears, not chains.
LMJD is offline
post #18 of 25 (permalink) Old 05-14-2015, 03:26 PM
chuckster57's Avatar
That's why I changed my 86 F250 460 to gear drive. Timing doesn't change with miles.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #19 of 25 (permalink) Old 05-15-2015, 09:44 AM
Bill1013's Avatar
I don't see any chains.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
post #20 of 25 (permalink) Old 05-15-2015, 09:45 AM
Could also be an ether start. With the tight clearances, and too big a shot of ether bad things happen.
oldrebuiltdodge is offline
post #21 of 25 (permalink) Old 05-15-2015, 12:10 PM
Not that ether
Son driving truck, all normal. Died abruptly...no lockup. Cranks over easily, too easily. no, or limited compression. No strangenoises when cranked. No oil, or brown scum in coolant, no water in oil. Before I start wrenching, would like to have an idea what it is. Timing gear stripped? Blown head or head gasket (no exterior sign of leaks? About 200k on motor.
post #22 of 25 (permalink) Old 05-15-2015, 01:44 PM
With 5 bent push rods? Pull the cover off of the access to the bolts for the IP gear. look at the bolts that attach the gear to it there should be three of them. It might be that one of them fell out and got caught in the cam gear, causing it to strip the teeth off and loose time. The bent push rods would be from pistons pushing valves shut. If that is the case, I would replace the gears, and push rods, then run a compression check to see if any of the pistons have holes in them, or maybe more likely valves are bent.
post #23 of 25 (permalink) Old 02-10-2019, 02:42 PM
Check out cavitation....do a search....have seen 2 7.3 idi with that problem.
1992 f-350.4x4 srw.rebuilt e4od.rebuilt injection pump. no soup bowl,no muffler,straight pipe.. 8 foot power angle Artic blade/7 1/2 ft p/a Fisher blade. 280,000kms and counting.Paint to come.
pnose is offline
post #24 of 25 (permalink) Old 02-10-2019, 05:14 PM
My Photos: (27)
Hopefully he's got it running by now, his post is 4 years old.
LMJD is offline
post #25 of 25 (permalink) Old 02-11-2019, 03:41 PM
Let me set the record straight in case there are some who still aren't sure. The engine does not have a timing chain. It does have timing gears. Here are links to some pictures in case you still are unsure.
http://www.blackwire.com/~bjordan/Te....3_IDI_101.pdf
Aligning the IP Timing, Camshaft, and Crankshaft Gears on a 6.9 / 7.3 IDI Engine ? IDI Online
LMJD likes this.
DonWarkentin is offline
