Hi everyone! i am very new to this forum ( just signed up 2 minutes ago) . i am currently getting my 1991 Ford F-250 into tip top shape and i had a question, right now im 15 so i want to trick this truck out. if i straight piped it, what would be the pros and cons of doing this, also, i do not know if my truck would sound good, so i was wondering if anyone would have suggestions, also!, my truck does NOT have a turbo on it, it is bone stock. thank you
yea man i have had several idi they r loud str8 piped but brings out the power. things to watch for inj o-rings they go occasionally keep a fuel filter in ur box or keep it changed regular and enjoy they r bullet proof
there is a coolant additive, you can buy coolant that comes with it or you can buy it separately. napa can sell you something, or go to a tractor store and ask for coolant with diesel cooling additive for a ford.
also another question. my truck has been sitting for a good 3-4 years ( over that time i started up, but didnt drive it on the road). other than checking the fluids and replacing filters, is there anything i need to worry about?
I have been pulled over twice for my turbo straight pipe for noise violations and I have 3" from the turbo back I would look at your local laws before you straight pipe it to see what the bylaws say about excessive noise from your truck.
DO WHEEL BEARINGS. I am also a teenager with one of these trucks, a 1984 6.9 idi non turbo, straight piped, and i neglected to do simple maintanence for a long time such as wheel bearings, greasing ball joints, tie rods, etc, and i ended up stuck 6 hrs from home on a road trip with a siezed wheel bearing. had to get towed home, new hub and rotor, etc. just over $600 in the end. bought the bearings for the other side for 30 bucks and did it in about 2 hrs on the first try. Save yourself the trouble of towing, etc. also, mine is straight piped as well and i think in sounds great. 25k miles in a year and half all over new england and no trouble, just keep an eye out for cops and lay off the gas if you see one
I got a 7.3 and a few things I am uncertain about is the fuel pump I'll start and drive it for a hour and then u shut it off and it doesnt want to start unless u pour water on the fuel pump and I was wondering whays the best way to straight pipe and make it sound good
Start by replacing your IP. Having to pour water over it means it is wore out. Straight pipe? if you're going to do it, go all out. put dual stacks out behind the cab, and end them at just about window height, then you'll be sure to hear it.
My 93 non-turbo came straight piped via the exhaust rotting just ahead of the muffler. Without a turbo, it sounds like any big block v8. I personally dont care for it. I'm also 40 and have my own business, so I need to keep that "professional image"
I agree. I have always liked to hear myself think. I also have spent so much time around loud engines, I just don't want to listen to them any more
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
