7.3L IDI with aftermarket turbo, fuel filter light - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 05-20-2018, 02:10 PM Thread Starter
CowboyMoyer's Avatar
howdy yalk sorry it me again same truck 1993 crew cab dually with 7.3 idi with ats aftermarket turbo, well whats it doing is the fuel filter light comes on a second later it dies, i have change fuel filters and new fuel pump and new fuel return lines, and a used fuel selector valve on frame still doing the same, if i can get it up and running i woukd be happy
CowboyMoyer is offline
post #2 of 6 (permalink) Old 05-20-2018, 02:34 PM
Fuel filter light means there's a vacuum at the filter head instead of pressure, right?
Are all your lines (feed and return) actually open? If something's plugging up the feed lines from the tanks to the lift pump, it won't be able to flow anything. Crud in the tanks blocking the pickup?
Have you tried feeding the filter directly from a can of diesel... then feed the lift pump from a can, and keep going back until you've found the obstruction.
Charles-65F350 is offline
post #3 of 6 (permalink) Old 05-20-2018, 03:22 PM
If the trouble is common to both tanks, I would start with a plugged fuel line from the select valve to the lift pump. You can also blow back to the tank(s)from the inlet to the lift pump with compressed air. Make sure the caps are off the tanks. Then try to prime and start it again...or you mayhave been sold a bad lift pump. Did you put it in right? The lever goes under the cam lobe, and yes you can get it in wrong.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #4 of 6 (permalink) Old 05-20-2018, 03:38 PM Thread Starter
I installed it while motor was out, this motor was rebuild 400 miles ago, I drop both tanks( was hell with both full) but I cleaned them out and blow tho the lines and had my gf change tanks and it worked air going tho, but fuel and getting to filter but idk about out of the filter
Last edited by Dick Cutting; 05-20-2018 at 06:19 PM. Reason: I fixed 3 of your i words that were not as capital letter. i was suposed to be as I
post #5 of 6 (permalink) Old 05-21-2018, 12:43 AM Thread Starter
i got it fixed it was the fuel tank selector valveon frame, but did not buy new one i done a by pass with hoses, cause ones at autozone and O'Reilly was not the same as my old one, it was cheaper for me to put ts and houses with claps, works for me
post #6 of 6 (permalink) Old 05-21-2018, 04:40 PM
I've been guilty of cobbleing in an after market tank selector valve a time ot two myself.
One...dare I say it...form a General Motors product!!
