'92 F350 Navistar International 7.3L IDI found non metalic like metal on oil change - Diesel Forum - TheDieselStop.com
 2Likes
  • 1 Post By oldrebuiltdodge
  • 1 Post By Trucker87
post #1 of 4 (permalink) Old 04-25-2018, 12:02 PM Thread Starter
Truck runs great. Oil changed like clockwork. Changed the oil and found aluminum shavings, almost like glitter in the oil. Stopped driving truck but cannot figure out where this is coming from? Removed crankcase cover to check on low oil gear, looks fine. This non metalic substance is found here also. Any help would be appreciated smile2:
AngieM is offline
post #2 of 4 (permalink) Old 04-25-2018, 04:13 PM
Time to pull the pan and look at the bearings. What you're seeing is bearing material. If you can get the pan off without pulling the engine even better.
AngieM likes this.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #3 of 4 (permalink) Old 04-26-2018, 09:00 AM
By what your saying "crankcase cover", do you mean the oil pan? and what is the low oil gear?
It's very difficult to pull the oil pan without jacking the engine up, which in turn is difficult also. It's much better to pull the whole engine and put it on a engine stand. Fully dressed, these engines weigh close to a thousand pounds, it's better to have a two thousand engine stand. The 0ne ton shop crane is sufficient.
These engine oil pans where sealed at the factory with RTV (Ford TA-31), which is very difficult to remove from pan rail and pan, all of it has to be removed down to a shinny surface or when sealed up again, they will leak again forever.
Harbor Freight has a very good 2000 lb. engine stand.
https://www.harborfreight.com/2000-l...and-69521.html
and https://www.harborfreight.com/1-ton-...ane-61858.html
AngieM likes this.
92 F350 Lariat, 2WD, Dualie, CC, LB, E4OD Trans, Banks Sidewinder turbo, GV O/U, Pyro, Boost, Oil temp, Trans temp. Chassis 129K, Engine 7.3L 75K. Bench seat.
"99.5 F350 7.3 PSD 4R100 CC LB 4X4 DRW 4:10 Centurion Conv.
ScanGaugeII SPDiesel Performance Module 40-60-80 HP -- A Pillar - Boost - Pyrometer - Trans.Temp. - Engine Oil Temp.GN Hitch 20K -- Reese 16K 5er Hitch - Draw Tite Brake Control - Aux. Trans. oil cooler - 100 Gal. Transfer Flow fuel tank, W/Trax II computer. DIY black bed liner. Red Knight
IDI firing order 12734568--------1&4-2&5-7&6-3&8 Cyl's @ TDC. 1&4 TDC when timing mark is @ 0. Each 1/4 turn, next 2.
Trucker87 is offline
post #4 of 4 (permalink) Old 04-29-2018, 10:22 PM
genscripter's Avatar
That sounds like one of your crank or rod bearings disintegrated. I had similar carnage when my rod bearing went to hell. 7.3 IDI Crank-Rod Bearing Crisis ? IDI Online
Like the other posters said, you'll need to pull the pan to diagnose it.
genscripter is offline
