97 f250 7.3 4wd trans compatibilty - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 11-24-2019, 10:45 PM Thread Starter
can I use a e4od out of a 93 7.3 in my 97?
ksg1981 is offline
post #2 of 3 (permalink) Old 11-27-2019, 02:52 PM
I would think it would have trouble getting a shift command, because of the computer in the 97. I don't know, that would just be my guess. The trans. in the 93 is fed from the speed sensor, and the tach. sensor. the 97 is too, but it is all fed to the on-board computer, then to the trans. I don't think they would be compatible, but I've been wrong before too. There also might be a way to switch all of that stuff over. In which case, I don't see any reason it won't work, they will definitely bolt up. I am running a ZF5 from an 89 on my 93.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #3 of 3 (permalink) Old 11-27-2019, 06:51 PM
Mark Kovalsky's Avatar
My Photos: (6)
It's been awhile, but I think if you change the TRS on the driver's side of the trans and the solenoid body it should work fine. The other difference is that the torque converter on the '93 has four studs and the torque converter on the '97 has six studs.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
