ABS Light - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 09-05-2019, 02:13 PM Thread Starter
caseyj's Avatar
ABS Light
My ABS light stays on all the time? What should I check for? Thank you in advance.
1994 F250 HD, IDI Diesel, 3:55 gears, K&N filter, Hayden Tranny Cooler, Monroe HD SensaTrac shocks, dual pillar pod with temp & tranny guage, poly fuel tanks,aluminum racing radiator
caseyj is offline
post #2 of 3 (permalink) Old 09-05-2019, 04:32 PM
bugman's Avatar
My Photos: (12)
You need to pull the codes. You don't need a code reader but you have to ground a wire below the glovebox and count the ABS light flashes for the code.
I'm sure that if you did a search on here you will find a thread on it.
Other than that is your speedometer and transmission working alright? I'm just guessing that you have automatic
Sent from my SM-J737V using Tapatalk
bugman is online now
post #3 of 3 (permalink) Old 09-05-2019, 05:24 PM Thread Starter
caseyj's Avatar
Thanks Bugman. It turned out that my emergency brake was not fully in the off position.
caseyj is offline
