Air Intake - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 05-19-2010, 12:41 PM Thread Starter
Question Air Intake
im looking to get rid of this stupid soup boul air intake and get something esle is this possible if not what can i do to make the air intake better
1988 Ford F-250 Custom 4x4 7.3 IDI International Diesel Three speed C6
American Diesel 7.3IDI is offline
post #2 of 14 (permalink) Old 05-19-2010, 09:53 PM
fergy94f250's Avatar
you can custom make one for under 400 bucks witha afe cone filter i was going to do it but ran out of money when i had to replace the rad
94 F250 5 speed 7.3 IDI turbo 4x4 ext cab long box
fergy94f250 is offline
post #3 of 14 (permalink) Old 05-19-2010, 10:03 PM
best bet is to make your own you could even do it outta pvc and paint it, believe me it can be done
coalroller94 is offline
post #4 of 14 (permalink) Old 05-19-2010, 10:08 PM
i got a quote for my custom air intake about 400 bucks with filter that is all the piping clamps and the elbows to bring it to the driver side like it sits now easy to do and after and hour or to and you can have it done
i'd stick away from pvc looks shoty and kinda cheap even painted
post #5 of 14 (permalink) Old 05-19-2010, 10:19 PM
hey im new to this sight, and im not sure how to set my own thread... but i was just wondering... i have a 89 ford diesel and i was thinking about putting a turbo on it, what is the best turbo and is it worth it?
89ford7.3dsl is offline
post #6 of 14 (permalink) Old 05-19-2010, 11:47 PM
Plywood's Avatar
My Photos: (13)
Apparently this is supposed to work on our trucks- 2001 DODGE RAM 1500 PICKUP AirAid Cold Air Intakes - AirAidSales.com - AirAid Products
And this one for sure does- Hypermax - Catalog
85 F250 XLT Lariat 4x4 7.3L N/A, C6, 315/75/16 Siped Wild Country Muds, Manual ZD9s, K&N, Soup Bowl Out, Dura-Lift Pump, Dynomax 3" Y-pipe-4" AFE Muffler-5" Turndown.
Turn it up!
Plywood is offline
post #7 of 14 (permalink) Old 05-20-2010, 01:21 AM
7.3_idi is offline
post #8 of 14 (permalink) Old 05-20-2010, 07:31 AM
not if you do it right ill try and get some pics on here
post #9 of 14 (permalink) Old 05-21-2010, 12:32 AM
88beast's Avatar
i used a sbc style air cleaner with a 3 inch tall element
then i made a 2.5 inch riser out of sheet metal self tapper screws and silicone to seal it up
much better flow and you dont have to check the filter to see if its dirty just peak under the hood plus chrome on an idi looks great
88 f250 96 bed 95 front clip western mirrors and big ole bumper.
7.3 idi t70, 3g, g31,
other mods, oba, warn winch, big steel goodies including a headache rack etc.
check out my site at
88beast is offline
post #10 of 14 (permalink) Old 05-21-2010, 04:33 AM
CDX825's Avatar
My Photos: (11)
Send a message via AIM to CDX825 Send a message via Yahoo to CDX825
Allot of people will disagree but the stock filter is going to be better than a small cone filter. Especially one mounted in the engine compartment pulling warm air.
I would remove the soup bowl and set up ether ram air or cowl induction. If your still not happy get an aftermarket drop in filter such as a K&N or AFE etc.
Cone filters to me are cheezy and cheap and scream "ricer" and unless you get a big one you will have no where near the surface area of the stock filter.
-Justin
1984 F250 6.9 C6 2WD Push Button Glow plugs, No Soup bowl. Wix 33439 Water Separator, Carter P4594 fuel pump, Custom 3" Exhaust, NTZ Oil Bypass Filter, VDO Vision water temp gauge, ISSPRO EV Pyro
CDX825 is offline
post #11 of 14 (permalink) Old 05-21-2010, 10:03 AM
88beast's Avatar
thats why i did mine like i did my buddy has one on his and its so gutless he cant find out why and wont listen
i plan to run a cone filter after i go turbo but itll be huge and mount right off the turbo
88beast is offline
post #12 of 14 (permalink) Old 05-21-2010, 10:41 AM
drinkypoo's Avatar
My Photos: (25)
Here's pics of my rice boy intake on my pickup. Still working out what I'm doing with the CDR. I intend to keep it though, with the POSSIBLE exception that I'd consider an oil sep instead...
For those too lazy to follow the link, I bought a 1997+ intake, cut it and put it on my Impreza, took it off the Impreza when I sold it (buyer wanted a quiet car) and then I cut it up some more, bought one more silicone sleeve, and made an intake for my F250. I wrapped the stock paper filter in a circle and it was still smaller than the "ricer" cone filter; meanwhile, cloth breathes better than paper. I clean and oil it periodically with a K&N kit. Pedal response improved noticeably over the stupid aluminum ATS airbox and crap paper filter. I put the cone up at the front of the engine bay where it gets a little cooler air, but I'm still thinking about ways to bring in more cold.
Short form, even a ten dollar eBay cone filter kicks the crap out of the paper rectangle. Take 7.3_idi's advice and buy an intercooler piping kit, you can run that cone about anywhere you want. Aluminum piping cuts easy with a hacksaw in a miter box, or insanely easy with a cut-off wheel in a miter saw. For turbo trucks, a shorter intake leads to less turbo lag, so be conservative with piping. You can put the cone in a SUFFICIENTLY LARGE can, and bring piping into the end of the can for a cold air extension, allowing you to mount the cone wherever you like, and to bring in cold air from anywhere you can run the piping. Come to think of it, a can like that might be a good place to mount a CDR if you decide to keep it. The relative merits of various intake designs have been discussed absolutely to death by import tuners, to whom this stuff is highly relevant. Good luck!
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
post #13 of 14 (permalink) Old 05-22-2010, 05:59 AM
My Photos: (13)
The hypermax cowl induction is a worthwhile investment. I noticed the power increase right off the bat, and the egts drop about 300+ deg across the board
'92 F-350 Crew Cab dually,7.3 5 spd+ 3 speed Spicer 5831 Brownie, Solid Flywheel w 12 1/4" Kevlar Clutch, ATS turbo, Hypermax Cowl induction, MS Tech Fan Clutch, Custom Aluminum Rodney Red Radiator, 4" Exhaust, Air seat, Western Hauler bed.
RLDSL is offline
post #14 of 14 (permalink) Old 05-22-2010, 08:51 AM
drinkypoo's Avatar
My Photos: (25)
I'm actually seriously considering a hood scoop. If you combine that with some of that heat blanket stuff you can build a nice cold air intake. I want a nice smooth scoop though, no bird catching for me (that's what the grill is for!) Alternately, I think it would be brilliant to do a top-mount intercooler, but I've never seen any big enough. You'd need two. With even a small body lift there would be PLENTY of underhood room... Maybe even without one.
