Another New Guy with starting issues - Page 4 - Diesel Forum - TheDieselStop.com
post #46 of 52 (permalink) Old 03-01-2016, 05:00 PM
Originally Posted by Xeonpony View Post
(Off topic new forum lay out looks horrible <_< )
Go into your profile and choose the Classic view.
Edit - you can also scroll to the bottom of any page, there's a drop-down on the left side that says "TheDieselStop.Com (Full)". Click that and switch to Classic.
madpogue is offline
post #47 of 52 (permalink) Old 03-01-2016, 06:33 PM
MUCH better! Thanks.
New truck: 1988 F-350 1 ton dualy 2*4, 7.3L IDI Naturally Aspirated, Dual tanks with Camper package.
Mods: Enhanced gauge cluster; Transmission temp, rear diff temp, coolant system pressure, Vacuum pressure, Fuel pressure, Crappy tire Air horn Kit, Raycor pre filter/water sep. All LED Dash lighting, Parker LFS tranny filter, super duty tranny cooler, gerret turbo, waste gated (pending).
Xeonpony is offline
post #48 of 52 (permalink) Old 03-06-2016, 02:22 PM Thread Starter
Instead of tearing the ignition system apart, I'm going to wait until the problem resurfaces to diagnose it. I suspect it's in the column but that's just a hunch right now. Thanks for all of your input guys.
I had a heck of a time going through old posts on here finding the right part number for the fuel heater o-ring but for everyone's info it's IH 1811053C1. That is obviously the IH part number, nobody carries the Ford version anymore, so I won't bother with that. I ordered mine through finditparts.com, which was the only direct shipping website that had them. The guys at my nearest IH dealer were more than happy to order some, but it didn't make sense to drive all the way down there. The only other solution I found was to order a replacement heater assembly for 140 from IH that would come with the o-ring. Hopefully that doesn't become necessary. I'd definitely eliminate the whole thing before doing that.
So while I'm waiting for my o-rings to show up I am trying to figure out why I barely have a dribble of fuel in the return lines on the DS. I've attached the video of me cracking the #2 injector line. There was no real significant bubbling, and I think the spray was as strong as it should be, but I would take input from more experienced guys of course. It ran rough while loose then smoothed out when I tightened back down. If I'm right on that, then I have to think that the #2 return bonnet isn't sealing well. It's the only one that wasn't replaced by the mechanic when they pulled the DS head off, and here's why: the new kits have a 2 way outlet on the front DS, but my original has a 1 way going towards the rear. Looking at the set-up now, there is a metal line coming up from the rear of the block at a 4 way junction of return lines. Should I just eliminate that, run a 3 way junction with the regular soft lines, and use the 2 way on the front DS with the IP return line hooked to it? Is there a place to buy these caps individually or do I need to buy a whole return kit? Or do I just beg them off of mechanics?
1989 F350 Lariat Automatic 4x4 Crew Cab Long Bed (The Voluptuous Big Red)
7.3L IDI Non Turbo (for now...)
RLTW1988 is offline
post #49 of 52 (permalink) Old 03-06-2016, 07:37 PM
Used to able to get to get them on rock auto cheap, I just looked now to find you the link but I can no longer find them <_< but I have it set to cad currency only (Not sure if it is effecting the resualts)
Xeonpony is offline
post #50 of 52 (permalink) Old 03-06-2016, 07:40 PM
chuckster57's Avatar
I used a Viton O ring, rolled it onto a ratchet extension, and rolled it against my grinding wheel. I messed up a couple but I was able to make one that hasn't leaked for 6 years now.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #51 of 52 (permalink) Old 03-06-2016, 07:58 PM Thread Starter
Chuckster are you saying you used a grinder to fit the o-ring or were you referring to the bonnets for the return lines?
RLTW1988 is offline
post #52 of 52 (permalink) Old 03-06-2016, 08:43 PM
I used the grinder to create a flat edge for the fuel heater seal.
Train Horns:
