axle question - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By DevilDog6154
post #1 of 10 (permalink) Old 08-05-2019, 10:03 PM Thread Starter
axle question
i have a 90 f350 with 7.3idi non turbo 2wd. i recently changed my brakes and noticed that my axle bearings are leaking. what all should i replace? i know if they are worn enough to leak there is other things that are to.
90 f350 2wd 7.3idi non T 5speed
DevilDog6154 is offline
post #2 of 10 (permalink) Old 08-06-2019, 07:22 AM
My Photos: (27)
If the axle seals are leaking bad enough to get oil on the linings you'll have to replace the brake shoes too. The oil penetrates the linings and won't clean off. When the brakes get hot, more oil comes to the surface.
LMJD is offline
post #3 of 10 (permalink) Old 08-06-2019, 10:53 AM
Bearings don't leak, it is the seal that bad. Just inspect the bearings they should be good unless you ran out of lube in the axle. LMJD is spot on if the brake linings are wet replace them. While you have it up good time to replace the fluid in the diff.
DENNY
DENNY is offline
post #4 of 10 (permalink) Old 08-20-2019, 09:50 PM Thread Starter
right i knew the bearings wasnt the ones leaking should have worded that different. how would i determine what bearings and seal to buy?
post #5 of 10 (permalink) Old 08-21-2019, 08:05 AM
My Photos: (27)
99% of the time axle bearings in a full floating axle like you have last forever, so inspect them but they're probably OK. They came out with an improved axle seal years ago and any decent parts house should stock it. Brand is a CR Scotseal. Don't know if the 350's and 250's have the exact same rear end, but the axle seal part number for my '91 F-250 is CR Scotseal 34384.
Forgot to mention, even though your wheel bearings are lubed with differential oil, all shop manuals for all trucks say after cleaning and inspecting them, pack them with wheel bearing grease before reinstalling.
LMJD is offline
post #6 of 10 (permalink) Old 08-21-2019, 11:34 PM Thread Starter
thank you. if i do need to replace them do i go off the metal tag on the pumpkin for the right size bearings? also how do i know what size wheel bearings to get for the front?
post #7 of 10 (permalink) Old 08-22-2019, 07:56 AM
My Photos: (27)
Tapered roller bearings most always have a part number stamped on the edge of the race. However years ago I heard of some way off-brand oddball Chinese bearings that were not marked, if you run into that, take your old ones in to the parts house. Make and model of truck usually works too.
LMJD is offline
post #8 of 10 (permalink) Old 08-23-2019, 11:47 PM Thread Starter
thanks
LMJD likes this.
post #9 of 10 (permalink) Old 08-29-2019, 08:07 PM Thread Starter
How do I identify what axle I have other then the tags on it. I have one tag 10.10 2 9H22 V108C or V188C. What's that tell me?
post #10 of 10 (permalink) Old 08-30-2019, 09:09 AM
My Photos: (27)
Ya got me. I am under the impression trucks of this era had a small stainless silver tag bolted to a differential cover bolt that said the ratio. Like mine says LS3:55 (limited slip, 3:55 ratio) if I remember right.
LMJD is offline
