Bed Removal - Diesel Forum - TheDieselStop.com
LinkBack Thread Tools
Old 02-03-2013, 10:26 AM Thread Starter
caseyj's Avatar
Bed Removal
I noticed that some of you have removed your truck bed to work on your fuel tanks. I have this task coming up and so I was wondering what your experience was? I might also add that I have experience installing a new fuel tank laying on my back so I know what that entails. How did you go about it? Did you utilize a tree branch with block and tackle or wench it off back wards? Seems like there would be a lot of wire disconnects. Thank you for any responses.
1994 F250 HD, IDI Diesel, 3:55 gears, K&N filter, Hayden Tranny Cooler, Monroe HD SensaTrac shocks, dual pillar pod with temp & tranny guage, poly fuel tanks,aluminum racing radiator
caseyj is offline
Old 02-03-2013, 10:37 AM
RT
RT's Avatar
Bed Removal
I'm sure the OBS is the same or very similar. Very few wires to disconnect. There are 1-2 plugs in the rear where the wiring along the frame jumps to the taillight wiring and trailer connection. You can either get 4 friends to help lift or cut a 2x4 to fit under your bed rails to lift with an engine hoist or whatever you've got. Also, don't forget to disconnect the fill hose at the fill door(s)
Sent from AutoGuide.com App
RT is offline
Old 02-03-2013, 10:50 AM
chuckster57's Avatar
Bed Removal
RT has it nailed. Only thing I do is leave the rear bolts on but with only 2 or 3 threads in the nut. That way it can't slip and hit the ground. I use a strap across the front stake holes and my engine hoist.
Train Horns:
PM please not visitor message
chuckster57 is offline
Old 02-03-2013, 11:27 AM
drinkypoo's Avatar
My Photos: (25)
I remove the D/S bolts and loosen the P/S and then I slip a 1x1 steel tube into one of the tubes in the frame and jack that... after dealing with wiring of course. Gives access.
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
Old 02-03-2013, 01:55 PM
If you have a open frame garage you can put a 4x4 across 6 rafters and use a come-along and lift it up enough to drive it out from under it. there was two plugs at the rear above my trailer hitch, one for each side. and if your going to leave if off for a bit two saw horses will hold the box.
1993 7.3 IDI, crew cab, long box, 4x4 and a half, XLT with ATS turbo.
Glowshift Boost, Trans, Pyrometer gauges with glow shift pod.
Devdg is offline
Old 02-04-2013, 10:57 PM
93 7.3 banksturbo's Avatar
I lifted mine off with a bucket loader and put a peice of plywood between the cab and bed/rear window, but 4 people lifting is no sweat too. totally worth taking the bed off for access to the tanks.
1993 f-250 7.3l xlt, banks turbo, ext. cab long bed, two tone brown n tan, 160k, rebuilt e4od, ofi ip, bb codes, 4" banks straight pipe. (big brown)
93 7.3 banksturbo is offline
Old 02-05-2013, 07:26 PM
its no sweat unless you have rust in the wheel wells. every truck i've ever owned i had to take the bed off for something or another and each one had really bad rust in the wheel wells so the sides of the bed kept moving as we were carrying it. talk about a circus.
91' dakota 3.9l 4x4 103k ~ scrap
89' f250 7.3l 4x4 140k ~ toy/hauler
81 Kawi kz550 12k ~ resto project
98' intrigue 3.8l 185k ~ dd(definitely disabled)
R.I.P. my brother Andrew O. 12/12/1990-9/26/12
R.I.p. love of my life Sarah G. 4/12/1990-8/3/2012
dustyrider is offline
