Block Heater - Diesel Forum - TheDieselStop.com
 17Likes
post #1 of 27 (permalink) Old 01-04-2019, 09:32 AM Thread Starter
Block Heater
In cold weather, how long can you leave the block heater plugged in? My neighbor said I shouldn't leave it plugged in for more than 5 hours on these IDI engines. I'd like to leave it plugged in over night instead of getting up early and plugging it in at 5 or 6 am. thank you.
BGindesert is offline
post #2 of 27 (permalink) Old 01-04-2019, 09:40 AM
I have left mine plugger in over night before, lots of times, one truck have had for over 10 years now , with out any problems. Right or wrong don't really know.
LMJD, tbeck and oldrebuiltdodge like this.
Randy 4614 is offline
post #3 of 27 (permalink) Old 01-04-2019, 10:01 AM
bugman's Avatar
My Photos: (12)
You can leave it plugged in 24/7/365 and the only thing you are going to hurt is you wallet when you go to pay the electric bill.
But in the long run it doesn't do any good to leave it plugged in much longer than 3-4 hours before you need the truck. Just get a heavy duty 15-20 amp timer and set it for that long before you need your truck.
Now if you are not paying the electric bill then by all means plug it in when you get home and just leave it plugged in.
LMJD, tbeck, MrTommy and 1 others like this.
bugman is offline
post #4 of 27 (permalink) Old 01-04-2019, 10:25 AM
My Photos: (27)
When my pickup was my daily driver I had the heater on a 1500 watt timer. I found even at 10 below, 2-3 hours of heat was enough for easy quick starts. What was your neighbor's reason for no more than 5 hours? Like posted, doesn't hurt a thing.
LMJD is offline
post #5 of 27 (permalink) Old 01-04-2019, 10:58 AM
Steve83's Avatar
Have you read the owner's manual &/or diesel brochure? The '92 edition says "...the heater should be plugged in at least 3 hours prior to starting. The use of the heater for longer periods of time will not cause the engine to exceed the thermostat setting." That implies that the heater has an internal t'stat which will cause it to cycle off once it reaches its design temperature. It's a 1KW heater, which means it draws 9.1 Amps @110VAC.
Steve83 is offline
post #6 of 27 (permalink) Old 01-04-2019, 12:33 PM
bugman's Avatar
My Photos: (12)
There is no internal thermostat on the block heaters on these trucks.
It is just a rod that is inserted into the coolant passage. It wont really get the coolant very hot just from it's design and no circulation of the coolant. That along with trying to heat up a huge block of cast iron.
LMJD and oldrebuiltdodge like this.
bugman is offline
post #7 of 27 (permalink) Old 01-04-2019, 01:27 PM
My Photos: (27)
Originally Posted by bugman View Post
There is no internal thermostat on the block heaters on these trucks. It is just a rod that is inserted into the coolant passage. It wont really get the coolant very hot just from it's design and no circulation of the coolant. That along with trying to heat up a huge block of cast iron.
Right, and with that said, there's no way that small 900-1000 watt element is going to heat a block anywhere near engine operating temp if the outside temp is cold enough to require plugging it in.
LMJD is offline
post #8 of 27 (permalink) Old 01-04-2019, 05:46 PM Thread Starter
Thanks fellows*for all the replies, Just bought this 88 super duty, first diesel. Was told hard to start in cold weather so just cking things out. Can't remember why neighbor said not more than 5 hrs. but next time I see him I'll ask again and let you know. I also couldn't think of a reason why because of all the trucks in colder areas then where I live. It might get down into the teens but not very often. Thanks again Bill
post #9 of 27 (permalink) Old 01-04-2019, 06:13 PM
bugman's Avatar
My Photos: (12)
Get the glow plug system working properly and if it just gets down into the teens you will never need to fire up the block heater.
bugman is offline
post #10 of 27 (permalink) Old 01-04-2019, 06:56 PM
I've started in negative teens before without the block heater. When it all works right, it will start every time.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #11 of 27 (permalink) Old 01-04-2019, 07:46 PM
79jasper's Avatar
I think I recall some northerners having to plug in when they get home while the engine is still warm, to be able to have any heat in the morning.
Sent from my SM-N960U using Tapatalk
79jasper is offline
post #12 of 27 (permalink) Old 01-04-2019, 10:38 PM
When it is really cold, below zero that is what I do. It helps a lot.
post #13 of 27 (permalink) Old 01-04-2019, 10:54 PM
ArcticDriver's Avatar
Heck, I plug in when the temps are even +30*F when its someone elses dime and I will leave it plugged in all night...like at a hotel.
When its my own dime I plug in when its +20*F sometimes, depends on if its windy since that wind will be pulling heat away.
I have read 80% of engine wear occurs during initial cold start, that may be an exaggeration but even if its 50% then its still worth it to me to plug in a couple hours.
Randy 4614 likes this.
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is offline
post #14 of 27 (permalink) Old 01-05-2019, 09:39 AM
My Photos: (27)
Right, and quite a few "keyboard mechanics" have argued wind chill only applies to living flesh. Park your truck on a 10 day in the sun with no wind and the cab will be way warmer than the same temp on a windy day. Even with a dark color the cold wind sucks the heat right out of the sheet metal.
LMJD is offline
post #15 of 27 (permalink) Old 01-05-2019, 11:10 AM
bugman's Avatar
My Photos: (12)
The wind does cool things off a lot faster but metal can not be cooled any lower than the ambient temperature that surrounds it.
The effect of wind chill is to increase the rate of heat loss and reduce any warmer objects to the ambient temperature more quickly. It cannot, however, reduce the temperature of these objects below the ambient temperature, no matter how great the wind velocity.
I do agree that a vehicle parked in the sun on a 10 degree day will feel warmer than the outside temperature and if a wind kicks up it is going to cool off but it will go no lower than what the temperature is outside of the vehicle. So it goes from lets say 50 degrees inside temperature down to 10 degrees as the wind blows across the metal of the vehicle. But the inside temperature will get no lower than 10 degrees.
bugman is offline
