Brake light not working one side only - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 09-15-2018, 07:58 PM Thread Starter
Driverís side brake light has quit working and it is not the bulb and not a bad contact. Is there a separate circuit for the left and right sides power to the brake light coming off the brake pedal switch? Maybe a loose connection on that side? I see they both run off the same fuse so that is not the problem.
Thanks you.
Rich
1993 7.3 IDI F-350
Former USCG diesel mechanic. Procedures described here are not for everyone. Your results may vary. Side effects may include tissue damage. Check with your doctor.
ob99email is offline
post #2 of 3 (permalink) Old 09-15-2018, 10:02 PM
Steve83's Avatar
Originally Posted by ob99email View Post
...not a bad contact.
How do you know?
No, but there is at the MFS. Click this & read the caption:
(phone app link)
You can find your truck's wiring at this link:
BBB Industries- Premium Alternators, Starters, Power Steering Products | TSB's & Wiring Diagrams
It requires an e-mail, but it doesn't check that it's yours or even real.
Steve83 is offline
post #3 of 3 (permalink) Old 09-16-2018, 08:35 AM Thread Starter
Break light not working one side only RESOLVED
Steve83, thank you very much!
This info was exactly what I needed since I didnít realize that the MFS controlled the brake light. Here is what happened:
Iíd been testing my brake lights without the power on as I often do when I hook up a trailer. (I test the turn signals first with power then the rest without power.) I didnít realize that the left turn signal switch was engaged and had caused a bypass of the brake light circuit on that side (as designed). After your reply, I was able to do a root cause analysis knowing what the MFS does and asked myself if I had maybe done the above. Tried it and found that is exactly what happened. Brake light is good. Thanks again.
Rich
