A/C line help - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 05-14-2018, 12:28 PM Thread Starter
17hdfxdls's Avatar
A/C line help
So I have identified the a/c leak in my truck and it ended up being the line that connects to the back of the compressor. Only problem know is that I cant seem to find the correct replacement line. So if anyone has replaced this line I would be extremely happy if you could tell me what line you replaced it with! I attached a picture of the old line and one of the new lines that didnt fit. My vehicle is a 94 f350 idi turbo.
17hdfxdls is offline
post #2 of 10 (permalink) Old 05-14-2018, 01:11 PM
RT
RT's Avatar
What part didn't fit? Looks like the exact line from the pictures.
RT is offline
post #3 of 10 (permalink) Old 05-14-2018, 01:47 PM Thread Starter
17hdfxdls's Avatar
The new hose in that picture is about 6 inches short on the long hose. If you look at the bracket that bolts up to the back of the compressor those metal lines are slightly different to. I have another picture of those metal lines I'll upload. Unfortunately I'm at work so I cant take any better pictures right now.
post #4 of 10 (permalink) Old 05-14-2018, 02:23 PM
Steve83's Avatar
How exactly did you determine that the line is leaking? Where exactly is it leaking? It would probably be cheaper, quicker, & easier to get it repaired locally. Put your location in you profile.
Steve83 is offline
post #5 of 10 (permalink) Old 05-14-2018, 02:28 PM Thread Starter
17hdfxdls's Avatar
I charged the system with 134a and uv dye. I found the uv dye leaking out from this hose. I couldn't find any uv dye anywhere else. I dont really want to spend hundreds of dollars at a shop getting it fixed if I could spend a couple bucks installing a new hose and charging with some 134a and a little oil.
post #6 of 10 (permalink) Old 05-14-2018, 02:30 PM
RT
RT's Avatar
What line did you buy? FOUR SEASONS 55315 appears to be the correct hose.
RT is offline
post #7 of 10 (permalink) Old 05-14-2018, 02:38 PM Thread Starter
17hdfxdls's Avatar
Yeah I thought so to but that's the one in the picture that's about 6 inches short. I tried multiple ways of routing the hose but it was always short. Never thought it would be difficult to find an a/c line! I think I might have found the right one but on top of the metal block where the sensor sits it looks different than my stock hose. Here is a link to a better picture of it. https://www.partsgeek.com/catalog/19...l#immersedview
post #8 of 10 (permalink) Old 05-14-2018, 03:26 PM
RT
RT's Avatar
I wonder if matching it up at your local NAPA would be advantageous as opposed to ordering it just hoping it will fit.
RT is offline
post #9 of 10 (permalink) Old 05-14-2018, 04:42 PM Thread Starter
17hdfxdls's Avatar
True... I'll head over there after work. Thanks for
post #10 of 10 (permalink) Old 05-14-2018, 11:07 PM Thread Starter
17hdfxdls's Avatar
Well I ended up finding the correct part number in another forum. The part number I was looking for was 55314 just in case anyone in the future stumbles upon this.
