CDR Part #'s - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 02-16-2010, 11:56 AM Thread Starter
dieseldirt's Avatar
CDR Part #'s
Want to R&R my CDR Valve, tube assembly, etc on my '94 IDI factory turbo.
No IH dealer nearby, talked to Ford guy, who understood the IDI Turbo thing.
Now I am confused about part numbers...
P/N's he told me:
"6A665 for CDR Valve" $66
"6A664 for tube assy" $50
"cant get grommet anymore"
P/N's i've found:
E8TZ-6A892-A "tube & grommet assy"
E3TZ-6A892-A "valley pan/valve cover grommet"
Can someone help me? I think I just need 2 or 3 ford part numbers: the valve, the tube assy, and maybe the grommet.
'94 F350 RC/SRW 7.3 IDI Factory Turbo 4x4 ZF5 3.55 Dana 60 (auto hubs) 10.25" Sterling + Detroit TrueTrac. 33x1250x16.5 BFG. Hypermax Cowl Intake. Factory downpipe to 4" exhaust . Visteon radiator, Group 31 batteries, South Bend Clutch/SMF, DMI Hitch, Connex 3300HP, Wilson 1000, Uniden BCT8, gun rack, Western V-Plow. 228K
'97 F350 RC/DRW 7.3 PSD 4x4 E4OD 4.10 Dana 60 (manual hubs) 10.25" Sterling. Dump Body. L-pack toolboxes. 118k
Hot Work Saws- Husqvarna 385xp x2, 372xp, 346xp, Stihl ms660
Member NRA, AHBA
dieseldirt is offline
post #2 of 17 (permalink) Old 02-16-2010, 06:28 PM
me too... I think I need to replace or clean mine up... seems to be leaking all over the valve cover... I notcied this last week when I was at dads.. (he is borrowning the truck for the winter)
jim's oilburner is offline
post #3 of 17 (permalink) Old 02-17-2010, 04:57 AM
cdnsarguy's Avatar
My Photos: (109)
Check these #s out.........
CDR valve..
Ford calls this item a "Adapter assembly for Crankcase Ventilation" Part number E3TZ-6A665-A or IH part #1805319C1
E3TZ-6A665-A ADAPTOR $66.32$ $47.71
Crankcase Depression Regulator ... The seal "donut" does not come with the CDR. The ford Part Number for the CDR Seal is E3TZ-6A892-A. ...
E3TZ-6A892-A GASKET - REGULATING $3.47$ $2.49
I do not have my files with me, so the tube info is the same as the PSD if anyone can get it. The above info prices are from Titus Will ford online dealer.
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #4 of 17 (permalink) Old 02-17-2010, 07:01 PM Thread Starter
dieseldirt's Avatar
yeah i'm thinking the 6A664 he told me is correct for the tube. 50 bucks, wow...
thanks alot, i appreciate it.
Member NRA, AHBA
post #5 of 17 (permalink) Old 02-17-2010, 10:11 PM
cdnsarguy's Avatar
My Photos: (109)
I think I paid $60+ for the tube......
post #6 of 17 (permalink) Old 03-06-2010, 08:10 AM
JimNDenver's Avatar
Post This is what my tube looks like ....
My breather tube looks like this.
I am going to check with Tousley Ford (a vendor here).
I have bought from them before.
Jim
1995 F350 2WD PSD w/ 4:10 - auto - dually - crewcab
JimNDenver is offline
post #7 of 17 (permalink) Old 03-06-2010, 09:47 AM
typefour's Avatar
jim are you moving again????
91 F350 crew cab 4x4 7.3 ats and intercooled with cut down 2000 ps cooler, bigger turbo comp,head studs, torque cam, coated rockers , balanced. very good power.
made 218hp/461tq on a mustang dyno lasst dec with 80k on the rebuild
pyro,boost and all stock guages ignored with mechanical real ones
Fugitive sandrail. type 4 2840 turbo fi, lots of fun
PM please not visitor message
typefour is offline
post #8 of 17 (permalink) Old 03-07-2010, 04:43 AM
JimNDenver's Avatar
Thumbs up Sunday morning in North Platte, NE
Hi Russ,
Yeah I am back on the road again .....
Sunday morning here in North Platte, NE
I will try to make Des Moines, IA by this evening
When you get a chance, PM me a price on rebuilding my ZF transmission ......
Thanks Russ
Jim
post #9 of 17 (permalink) Old 03-07-2010, 01:10 PM
CDR Removal
Hey guys I am trying to r&r the CDR on my non-turbo 7.3 and am having a little trouble. Is there are trick to getting it loose from the manifold? I have removed the the two bolts and tried to just pull it out but it doesn't want to budge. Is there something else holding it in the manifold I hate to tear something up by just muscling it out.
Thanks for your help!!
Pete
Pete
Western KY
Stock 1992 F250 4x4 7.3l idi Non-turbo, E4OD, 3.55 Gears
My kids call it the BEAST!
dieselbeast is offline
post #10 of 17 (permalink) Old 03-07-2010, 01:16 PM
johnboggs21's Avatar
i had to kinda push mine back and pull it up. Jus wiggle it around and it should come out.
1993 F-250HD 7.3L IDI E4OD 370,000 miles Now sporting a strait pipe and has the soup bowl mod.
I'm gonna sign my name in that diesel smoke and let the ones that come along behind me choke!
johnboggs21 is offline
post #11 of 17 (permalink) Old 03-07-2010, 04:56 PM
cdnsarguy's Avatar
My Photos: (109)
The part into the VP has rings which hold it in.........you chould be able to remove the CDR valve from it if the clamp at the CDR end is removed.......
post #12 of 17 (permalink) Old 03-08-2010, 10:13 PM
Uhhh what's the "VP"? Sorry, new to this stuff.
Pete
Western KY
post #13 of 17 (permalink) Old 03-09-2010, 06:28 PM
Plywood's Avatar
My Photos: (13)
Made me think for a sec too, it's the "Valley pan" just under the intake manifold that the CDR goes into at the bottom.
85 F250 XLT Lariat 4x4 7.3L N/A, C6, 315/75/16 Siped Wild Country Muds, Manual ZD9s, K&N, Soup Bowl Out, Dura-Lift Pump, Dynomax 3" Y-pipe-4" AFE Muffler-5" Turndown.
Turn it up!
Plywood is offline
post #14 of 17 (permalink) Old 03-14-2010, 03:02 PM
Oh, got ya. Thanks Plywood.
Now to figure out how to get those rings off easily. I can see something that looks like a clamp. But of course laying across the motor really gives me no leverage to be able to do much. Working on swapping out the GP's right now so I'll revisit the CDR after that.
Pete
Western KY
post #15 of 17 (permalink) Old 03-14-2010, 05:55 PM
Plywood's Avatar
My Photos: (13)
My CDR comes right out so I don't know.
Turn it up!
Plywood is offline
