Column Shifter and Truck won't go after coasting down a hill - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 05-04-2018, 02:29 PM Thread Starter
BajaBruin's Avatar
Whats up guys.
I just picked up a 1991 Ford F-250 7.3 IDI 4x4 automatic and I'm stoked on this being my first diesel. I've got a few things i need help with:
1. The column shifter is super sloppy and will not sit snug in Park, Reverse, Neutral, etc. I've looked all over these forums and cannot find the right way to fix this. On another website they were saying hanging a 3 pound weight on the shifter and then getting under the truck and undoing the shift cable to the tranny and tightening it up that way. is this correct?
2. When i'm coasting down a hill and then give it gas to go up an on-ramp for the freeway, the rpms will rev up but the truck won't accelerate. Half the time after a half a second, the back wheels/lockers bite and then i go. The other times, i back off the pedal and gas it lightly, it seems to catch. What is going on here?
3. Also, when i pull into work, we have this driveway that is on an incline. So i'm clear.....what i do is coast into the driveway and then gas it to go up the driveway. well the truck does not go, it acts like im in neutral. i hit the brakes and then gas it lightly and then i chug up the driveway.
4. in our parking lot, there are speed bumps. i'll hit a speed bump and then the truck acts like its not in gear anymore. I think it might be an electrical problem. I heard something about a neutral safety switch but not sure if the 1991 had one or not.
Thanks for your time and expertise. Cheers!
BajaBruin is offline
post #2 of 5 (permalink) Old 05-11-2018, 12:25 PM
The first thing I would do is check the oil level. It sounds like it is a littler low.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #3 of 5 (permalink) Old 05-14-2018, 10:55 AM
Steve83's Avatar
1) No. That's for '92-up steering columns. Yours has no cable. Click this & read the caption:
(phone app link)
The adjustment is probably in the middle of the shifter pushrod, between the column & transmission, above the front driveshaft. There are also hard plastic bushings at each end of the pushrod that can wear & become loose/sloppy. I think replacements are still available.
2,3,4) I agree - that's a classic symptom of low fluid. How old is / how many miles on the current fluid & filter? What brand & type is the fluid? Read this & the NEXT several captions:
(phone app link)
You should put all the truck's details into your signature so we don't have to go looking for them:
(phone app link)
Steve83 is offline
post #4 of 5 (permalink) Old 05-17-2018, 09:16 AM Thread Starter
BajaBruin's Avatar
Yes you are absolutely correct. The oil level was off. Thank you for your response. I will add the details in the signature now. On to the pushrod...
1991 F-250 XL 7.3L IDI 4x4, Banks Sidewinder Turbo, Automatic E4OD, 3.55, Extended Cab, Long Bed, 3" Straight-Piped Exhaust, Hayden Transmission Cooler, Hughes Performance Deep Aluminum Trans Pan, Bilstein Shocks, 1994 Lance Squire 8000 Cabover
post #5 of 5 (permalink) Old 05-19-2018, 11:58 AM
The proper way to check the tranny oil level is That the truck is running and in PARK or NEUTRAL and Tranny is HOT. That 14 quarts of oil can expand considerably making it an OVERFILL which is very bad on an E4OD.
Yours is not CABLE driven, it's thru shift rods. Put the tranny in Neutral, climb under and check the NEUTRAL lines marked on the MLPS for lining up. SEE pic.
As Above, check shifter rod bearings. There is NO SAFETY SWITCH as such, only a Manual Tranny has one.
If the Rod bearings are OK and MLPS lines are lined up and the oil level was extremely low, the COAST CLUTCHES clutches could be worn out.
92 F350 Lariat, 2WD, Dualie, CC, LB, E4OD Trans, Banks Sidewinder turbo, GV O/U, Pyro, Boost, Oil temp, Trans temp. Chassis 129K, Engine 7.3L 75K. Bench seat.
"99.5 F350 7.3 PSD 4R100 CC LB 4X4 DRW 4:10 Centurion Conv.
ScanGaugeII SPDiesel Performance Module 40-60-80 HP -- A Pillar - Boost - Pyrometer - Trans.Temp. - Engine Oil Temp.GN Hitch 20K -- Reese 16K 5er Hitch - Draw Tite Brake Control - Aux. Trans. oil cooler - 100 Gal. Transfer Flow fuel tank, W/Trax II computer. DIY black bed liner. Red Knight
IDI firing order 12734568--------1&4-2&5-7&6-3&8 Cyl's @ TDC. 1&4 TDC when timing mark is @ 0. Each 1/4 turn, next 2.
Trucker87 is offline
