Do these additives really work? - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By LMJD
  • 1 Post By bugman
post #1 of 15 (permalink) Old 09-13-2018, 04:28 PM Thread Starter
https://www.hotshotsecret.com/?utm_s...8057d453d4382c
94 F350 7.3 IDI Turbodiesel 4x2 CC E4OD transmission, 4.10 gear ratio, 10.25 ring gear, limited slip, single rear wheels, long bed, Tru-Cool Max 45k transmission cooler l
Hoko is offline
post #2 of 15 (permalink) Old 09-13-2018, 05:16 PM
RT
RT's Avatar
Some 6.0 owners report injector stiction being an issue and having luck with this product. Never seen stiction on a 7.3 DI and no way on an IDI.
RT is online now
post #3 of 15 (permalink) Old 09-13-2018, 05:24 PM
79jasper's Avatar
The stiction eliminator will help clean the engine.
The diesel extreme works, but only supposed to run it once every 6 months.
Sent from my SAMSUNG-SM-G930A using Tapatalk
79jasper is offline
post #4 of 15 (permalink) Old 09-14-2018, 08:31 AM
I put the Hotshot In my 99 7.3 when I bought it this past spring. It is amazing how clean the oil has stayed. Not the normal black diesel oil that you cant get off your hands. So Yes I say it works.
Randy 4614 is offline
post #5 of 15 (permalink) Old 09-14-2018, 11:53 AM
bugman's Avatar
My Photos: (12)
The black in the diesel oil is soot from the cylinder walls that gets washed off and into the oil. It is the filters job to get rid of it.
Hotshot would have nothing to do with cleaning the oil. Even their web site says nothing about cleaning the oil.
bugman is online now
post #6 of 15 (permalink) Old 09-14-2018, 01:09 PM
My Photos: (27)
Couldn't agree more, Bugman.
oldrebuiltdodge likes this.
LMJD is offline
post #7 of 15 (permalink) Old 09-14-2018, 03:10 PM
79jasper's Avatar
Yeah, something else going on. Lol or something hes not telling. (Like a bypass filter)
79jasper is offline
post #8 of 15 (permalink) Old 09-14-2018, 03:25 PM
ArcticDriver's Avatar
The post might have been saying that he used Hotshot when he bought the truck and his more recent oil changes are not as dirty.
SOLD:
ArcticDriver is offline
post #9 of 15 (permalink) Old 09-14-2018, 03:44 PM
bugman's Avatar
My Photos: (12)
I looked at the Hotshot web site and how clean some of the motors are on before and after shots. Problem is you can get them just as clean by running kerosene mix in your oil.
post #10 of 15 (permalink) Old 09-14-2018, 04:22 PM
Right, that's all most of that stuff is.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #11 of 15 (permalink) Old 09-14-2018, 04:30 PM
2000F250-7.3's Avatar
It has helped my 7.3 clean some of the coking out of my turbo and injectors. But the key to a 7.3 is use good filters and change the oil every 4,000 miles.
2000 F250 7.3 4inc exhaust, Ts 6 pos chip witch custom tunes, Built 4R100 w billet triple disc converter, 6.0 trans cooler and deep tans pan, CCV mod, 4 gauge pod A piller,Boost,Trans temp,EGT,fuel pressure AFE intake,RIFFRAFF Frx fuel Rail dead head fix black spring,High Flow banjo bolts,High Flow CVD Fitting, Harpoon mod,Diesel site adrenaline HPOP,AIH Plug,Plenum Reinforcing Inserts. FULL FORCE DIESEL STAGE 1.5 single shot injectors, Garrett powermax GTP38R and blank pedestal, RIFFRAFF Intercooler CAC Boots with complete clamp kit , scanegauge 2
2000F250-7.3 is offline
post #12 of 15 (permalink) Old 09-14-2018, 09:32 PM
79jasper's Avatar
Yeah, but that'll be harder on your bearings.
79jasper is offline
post #13 of 15 (permalink) Old 09-16-2018, 07:05 PM
My Photos: (27)
It's always been agreed upon by diesel mechanics and diesel engine reps that black oil means the oil is doing its job. I remember years ago a few people requested Havoline and it would turn black so quick a few people later accused the shop of not changing their oil, and this was in gas engines. Long time back, but I remember any life-long Havoline engine we tore down the tops of the cylinder heads were amazingly clean, no sludge whatsoever to be found.
LMJD is offline
post #14 of 15 (permalink) Old 09-16-2018, 07:12 PM
My Photos: (27)
You can't replace wear with chemistry. It's injector solenoid wear that causes the stiction in electronic engines.
LMJD is offline
post #15 of 15 (permalink) Old 09-16-2018, 08:14 PM
79jasper's Avatar
But it's not always wear causing stiction in a 6.0 injector. Many times the spool valves could be cleaned.
79jasper is offline
