Diesel Forum - TheDieselStop.com
Diesel Forum - TheDieselStop.com (https://www.thedieselstop.com/forums/)
-   7.3L IDI Diesels (Not Power Strokes) (https://www.thedieselstop.com/forums/f30/)
-   -   E40D Transmission Rebuild Question (https://www.thedieselstop.com/forums/f30/e40d-transmission-rebuild-question-432785/)
mexicanfooddude 04-29-2014 05:09 PM
Hi all,
I've got a '94 E-350 Box Truck with the 7.3 IDI and E40D. Last year when pulling a grade with O/D off, my cooling system gave out and the engine of course heated up. I didn't let it hit the red zone (before I figured out the cooling system had given out), but it got close. Almost immediately afterward the transmission randomly downshifted on the freeway, O/D started flashing, and something slipped - from then on, at low speeds and gears, there is a metallic ringing sound when shifting, and it shifts very poorly. I since have installed a new all-aluminum radiator and the cooling system is solid, but as expected the transmission issues continued.
The strange thing is that when I pull the battery cables, let the truck sit for a bit and then connect everything back up, the truck drives and shifts fine for anywhere from 10-100 miles, and O/D light doesn't flash. Then, it will randomly slip again and start shifting like crap. This happens everytime I pull the batteries - drives fine at first, then goes down the tube.
I took the truck in and two different shops told me that there was internal failure in the transmission and I needed a rebuild ($2850!). I've got trust in these guys so I believe them. For my own edification though, I'm wondering why the vehicle would drive fine for a short while after reconnecting the batteries. I was feeling like it must have been a speed sensor or something prior to taking it in to the shop. Hoping someone can just educate me a bit on what might be going on.
Truck has 185,000 miles, and served as a U-Haul for the first 50,000 miles of life. I know these transmissions had some issues in the first place, and I'm sure its time as a U-Haul didn't help extend the life of the transmission any. I was expecting an impending rebuild at some point.
Mark Kovalsky 04-29-2014 05:57 PM
I predict that your problem is a cracked torque converter clutch apply piston. That allows pressure that should be holding the clutch to leak past the clutch. This allows the clutch to slip. Once the slip exceeds 50 RPM for a certain amount of time (I've forgotten the time) it sets a slip code, flashes the OD light, and sets the transmission pressure high to try and protect the slipping clutch.
When you disconnect the batteries the code is cleared and the trans shifts normal. Once it recognizes the slip it sets the pressure high and the shifts bang.
The solution is a new torque converter. While the trans is out adding a rebuild is not that much more money.
mexicanfooddude 04-29-2014 06:42 PM
Thanks for the reply Mark. So I'm assuming from your reply that a transmission rebuild like the one I'm currently receiving does not include the torque converter? I'm concerned now that they may not have correctly diagnosed the issue... or perhaps the transmission AND the torque converter are in need of repair?
The mechanic just called and told me that in addition to the transmission rebuild kit and everything for $2850, after opening everything up they discovered that two "hard parts" are also in need of replacement: a planetary gear something-or-other, and a solenoid pack (the solenoids cannot be obtained individually). Now I'm looking at $3,300. So painful...
Mark Kovalsky 04-29-2014 07:31 PM
If the rebuild doesn't include a new or rebuilt torque converter they are incompetent and ripping you off. I can't imagine rebuilding a transmission and reinstalling the old converter.
Finding damaged hard parts is not unusual, and normally can't be detected until the trans is torn down.
mexicanfooddude 04-29-2014 08:17 PM
Thanks for the help Mark. I've got some confidence in them, so I'm sure it's included. I'll double-check though.
Bill1013 05-01-2014 08:02 PM
For $2850 rebuild, that should include everything that needs replaced, including the TC. You should replace the Aux cooler or add one if you don't have one. Tru-Cool is a good one.
Xeonpony 05-03-2014 01:48 PM
cheaper option for coole ris wreaking yard, find a superduty power stroke that blew up (Shouldn't be hard) and pull the trans cooler, wash it out good, order a parker lfs trans filter, and there ya be.
8gitmusik1 01-28-2019 08:34 PM
Im reviving this post to ask, where do you recommend I get a Parker IFS trans cooler and why do you recommend it with a pwerstroke transmission cooler? Wont this restrict the transmission fluid, flow rate?
Sent from my SM-T567V using Tapatalk
DonWarkentin 01-29-2019 02:31 PM
Tranny Filter Tech | Trailer Life
The maximum transmission fluid flow rate is 2-6 gallons per minute in light trucks.
The Parker Racor LFS 22825 flows 8 gallons per minute and has a bypass valve which opens when the filter becomes clogged.
Another option is the Magnefine filter, which has a flow rate of 7 gallons per minute and has a bypass valve.
A third option is the BD Diesel Performance filter, which has a flow rate of 20 gallons per minute and has a bypass valve. If you buy this product, do not delete the transmission cooler bypass. Instead, rebuild the transmission cooler bypass valve if it is sticking. https://www.transmissionpartsusa.com...-03660502k.htm
https://www.sonnax.com/parts/2078-co...pass-valve-kit
Here are some sources.
Sources
Magnefine Boss Products USA Boss USA
Racor Parker Engine Mobile Original Equipment - Parker, 800-344-3286
BD Performance www.dieselperformance.com, 800-887-5030
8gitmusik1 02-02-2019 09:21 PM
Sources
Great info. Im learning a great deal from your current and prior posts.
Thanks Don
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
