Eliminating fuel filter heater - Diesel Forum - TheDieselStop.com
 7Likes
post #1 of 24 (permalink) Old 12-18-2018, 02:39 PM Thread Starter
TKA ford's Avatar
Hey all, I'm ready to eliminate the fuel filter heater and have the 1/2" npt tap and matching drill bit. Question is what should I put on the treads to seal plug? Also , any tips from people that have done this already? Thanks
'88 f-250 NA zf5 4x4 208k miles
TKA ford is offline
post #2 of 24 (permalink) Old 12-18-2018, 02:51 PM
My Photos: (27)
Most all mechanics use the teflon thread sealant paste made by Locktite/Permatex company on any pipe plugs or hydraulic fittings. (White tube with red lettering)
oldrebuiltdodge likes this.
LMJD is offline
post #3 of 24 (permalink) Old 12-22-2018, 01:45 PM
Good stuff. I would add don't use tefflon tape. you can split your housing like that. Besides the strings getting everywhere.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #4 of 24 (permalink) Old 12-23-2018, 08:57 AM
ArcticDriver's Avatar
I have had good luck with Gasoila Thread sealant:
http://www.dieselorings.com/shop-sup...-2oz-tube.html
SOLD:
ArcticDriver is offline
post #5 of 24 (permalink) Old 12-23-2018, 03:38 PM
My Photos: (27)
Actually I've used the Permatex/Locktite tape a lot, but like the factory rep said, you have to start it a thread or two back tapering the windings, and most importantly, wind it on in the proper direction so it stays put. Been a life-saver winding it on thick on certain worn out sloppy hydraulic fittings.
LMJD is offline
post #6 of 24 (permalink) Old 12-23-2018, 05:35 PM
Tape.
+1 on proper direction 😉
+1 on taking the slop out of fittings.
SOLD:
post #7 of 24 (permalink) Old 12-23-2018, 07:54 PM Thread Starter
TKA ford's Avatar
Thanks for the info. I just found fuel dripping from steel line were it passes under oil pan on its way to lift pump. Can this line be replaced with hose? If not where do I find new steel line? Local shop doesn't have anything
TKA ford is offline
post #8 of 24 (permalink) Old 12-23-2018, 11:43 PM
I might continue to use a rigid line myself since it sounds like its upstream of the pump and the suction created could pinch a rubber line off...or atleast that would be my concern.
I am away from my truck but what are the attachments at the ends?
SOLD:
post #9 of 24 (permalink) Old 12-24-2018, 08:50 AM
Just fabricate one with 3/8 break line, use a bender to get nice clean bends.
New truck: 1988 F-350 1 ton dualy 2*4, 7.3L IDI Naturally Aspirated, Dual tanks with Camper package.
Mods: Enhanced gauge cluster; Transmission temp, rear diff temp, coolant system pressure, Vacuum pressure, Fuel pressure, Crappy tire Air horn Kit, Raycor pre filter/water sep. All LED Dash lighting, Parker LFS tranny filter, super duty tranny cooler, gerret turbo, waste gated (pending).
Xeonpony is offline
post #10 of 24 (permalink) Old 12-24-2018, 09:14 AM
Can not remember what the line ends are like, but if for hose can use a flaring tool to put a small flare on the end to help hold the hose.
Randy 4614 is offline
post #11 of 24 (permalink) Old 12-24-2018, 10:46 PM
I have used it extensively as well. I have also seen cast, and especially aluminum housings split wide open because someone overtightened a fitting with tape on it. Having been in the oil and gas industry, I have gone through more teflon tape than I care to think about. I simply tried to keep the OP from ruining his filter housing.
LMJD likes this.
post #12 of 24 (permalink) Old 12-25-2018, 01:00 AM
I think you guys are both right. PTFE tape is an excellent product for so many applications WHEN USED CORRECTLY.
The trouble is, and I don’t think this is an exxageration, the majority of guys don’t know how to use it.
There are alot of self-taught or YouTube DIY guys who mistakenly think its tape, how difficult can it be? The days of knowledge being passed down ended 20+ years ago so you have guys who don’t know telling new guys that don’t know.
And this holds true in the Oil & Gas Industry and not just the shadetree mechanic.
I see guys pulling it apart resulting in “strings” instead of cutting it, using too much, getting small particles or even metal shaving stuck to it, wrapping the wrong way, not wrapping snug, etc..
LMJD, oldrebuiltdodge and stumpman like this.
SOLD:
post #13 of 24 (permalink) Old 12-25-2018, 01:04 PM
Wapping it the wrong way, and ending it in the wrong place are the two most common mistakes...besides over using it. I have had to make up as many as 30 fittings at one time. You just don't stop to cut it off each time you finish. If you pull it off right it won't string. The strigs I referred to in my original post, were when the fitting is taken apart. You have to be careful not to get that stuff in a hydraulic system or something equally as sensitive. When that happens you can really make a mess. Then there is always the fool who puts new tape over old instead of cleanig it off.
MERRY CHRISTMAS Y'ALL
post #14 of 24 (permalink) Old 12-25-2018, 05:38 PM
I know what you mean about breaking it off clean but not with Arctic gloves on...Lol
I cut every length.
MERRY CHRISTMAS !
SOLD:
post #15 of 24 (permalink) Old 12-26-2018, 09:36 AM
My Photos: (27)
I can't do anything that requires some finesse with gloves on. To make things worse, I got my hands frost bit years ago flyfishing and my hand muscles are weak and the cold really gets to them. I asked my vet at the time what gloves are warmest and he said he didn't have a clue. Said one day his hands were so cold he lost a fingernail pulling a calf.
LMJD is offline
