Front tank won't take fuel - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By coreywj454
post #1 of 14 (permalink) Old 06-16-2019, 04:08 PM Thread Starter
Hi Guys. I am reviving my IDI. The rear tank sending unit broke off and the front tank won't take fuel so it has been parked for a while. I dropped the rear tank and installed a new 40 gallon and modified the old sending unit to work with it. Now I am on to the front tank. It will not take fuel. My truck has a utility bed and I always thought it was an issue with the angle but today I loosened the hose from the filler and tried to put diesel into the tube at a better angle and the tank still won't take on fuel. Is this just a venting issue? Or is there something else I should be looking at?
90 F250 7.3 NA, 5 speed, 4x4, extended cab with utility bed.
coreywj454 is offline
post #2 of 14 (permalink) Old 06-16-2019, 11:23 PM
Steve83's Avatar
The vent is the outer hose; the filler is the inner one.
(phone app link)
I recently repaired a '97 gasser flatbed by removing both filler neck assemblies, pulling the outer hoses, then the inner hoses, and replacing the inners with 1" PEX tubing from a hardware store. I used a common 110VAC heat gun to form it to follow the original hose's contour (checking frequently on the truck), and then put the outer hose back on before final installation.
Steve83 is offline
post #3 of 14 (permalink) Old 06-17-2019, 07:23 AM Thread Starter
My truck only has the outer hose so I am thinking thats the problem. I am going to take everything off back to the tank inlet and re-do it with an inner and outer hose and hopefully that solves the problem. My rear tank did not have the inner hose either but it seems to fill alright.
post #4 of 14 (permalink) Old 06-17-2019, 07:28 PM
Do yourself a favor, and put the inner hose in the back one too.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #5 of 14 (permalink) Old 06-18-2019, 08:51 AM Thread Starter
is 1 inch the size hose i need? I think I am more comfortable just getting fuel hose than going the pex route.
post #6 of 14 (permalink) Old 06-18-2019, 05:08 PM
Yes 1 inch is the correct size.
post #7 of 14 (permalink) Old 06-19-2019, 07:56 AM Thread Starter
I got some 1 inch hose and installed it. I am still having the same issue. it is acting like the fuel can't get into the tank. I think I am going to just drop the tank and see what is going on.
post #8 of 14 (permalink) Old 06-19-2019, 03:01 PM
Steve83's Avatar
Pex is more rigid & durable than rubber fuel hose - it won't collapse like hose does.
But it takes years for the hose to degrade, so it sounds like there's some other problem with your tanks. Did you try to look inside them while the filler hoses were off?
Steve83 is offline
post #9 of 14 (permalink) Old 06-19-2019, 09:43 PM Thread Starter
The rear tank is good to go. I can't see much into the front tank, i tried. the utility body on my truck makes it real hard to get in there, so I am just going to drop it and go from there. I am wondering if there was a filler hose and it broke off and is blocking the tank inlet.
post #10 of 14 (permalink) Old 06-20-2019, 09:20 PM
If the hose is too long, it will be a problem too. It should end right at the end of the outside hose
post #11 of 14 (permalink) Old 06-21-2019, 12:14 AM
Steve83's Avatar
This shows what I did:
(phone app link)
Steve83 is offline
post #12 of 14 (permalink) Old 06-25-2019, 06:09 PM Thread Starter
well i spent saturday fixing the filling issues.... and it turned out it was not a filling issue. Here i thought the whole time the tank was empty because the gauge was reading empty but turns out the damn tank was full and that is why it wasn't filling. I dropped the tank and pulled the sending unit. reconnected it to the truck electrical and moved the float up and down manually and the gauge moved accordingly. so i thought maybe it just got stuck or something. so i put it back in and the damn thing read empty. so i pulled it back out and took the float off of the wire.... the damn float was full of fuel so it wasn't floating. i drilled a hole in it, drained it, patched the hole with JB weld, then I took an eye drop container, hose clamped it to the float, snapped it back into place, put the sending unit back in and it is all working now.
oldrebuiltdodge likes this.
post #13 of 14 (permalink) Old 06-26-2019, 08:32 AM
caseyj's Avatar
I did what you did but the problem came back. Finally went to this type with no more problems.
1994 F250 HD, IDI Diesel, 3:55 gears, K&N filter, Hayden Tranny Cooler, Monroe HD SensaTrac shocks, dual pillar pod with temp & tranny guage, poly fuel tanks,aluminum racing radiator
caseyj is offline
post #14 of 14 (permalink) Old 06-26-2019, 07:43 PM
Steve83's Avatar
New floats are common & affordable. I bought a few spares last time I needed 2.
(phone app link)
Check Amazon & ebay.
Steve83 is offline
