Fuel heater O rings - Diesel Forum - TheDieselStop.com
post #1 of 15 (permalink) Old 04-16-2016, 01:33 PM Thread Starter
Question Fuel heater O rings
I have a 1990 7.3 with leaking around the fuel heater and leaking air back into the system. I disassembled the unit and as another post suggested using a 114 o ring which according to my set measures 5/8 ID, 13/16 OD and 3/32 thick. This size was too big and would not fit back together. So I used a size down, 016 o ring 5/8 ID, 3/4 OD, and 1/16 thick. This size was too small and it slid right but doesn't seal. I read on one post of using a A018 o ring, but I have not been able to find that size. Does anyone know what the dimensions are of an A018 o ring are? Also is there a metric size that would work instead for making this repair? Looking for suggestions Thanks..
Paul916 is offline
post #2 of 15 (permalink) Old 04-16-2016, 02:33 PM
chuckster57's Avatar
When I did mine, I used a Vinton O ring, and using a bench grinders. made the outer surface square. Hasn't leaked since '08.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 15 (permalink) Old 04-16-2016, 04:36 PM Thread Starter
I'm not sure I understand when you say you used a bench grinder to square it off. Are you talking about the o ring. You shaved off the outer part of the o-ring? And what size o-ring did you use?
Paul916 is offline
post #4 of 15 (permalink) Old 04-16-2016, 05:06 PM
I don't remember what size I used, but yeah I squared off the outer edge. When I took my old one out it looked Ike it had a square profile not round.
Train Horns:
post #5 of 15 (permalink) Old 04-17-2016, 11:37 AM
High quality lubricant and some force does wonders
New truck: 1988 F-350 1 ton dualy 2*4, 7.3L IDI Naturally Aspirated, Dual tanks with Camper package.
Mods: Enhanced gauge cluster; Transmission temp, rear diff temp, coolant system pressure, Vacuum pressure, Fuel pressure, Crappy tire Air horn Kit, Raycor pre filter/water sep. All LED Dash lighting, Parker LFS tranny filter, super duty tranny cooler, gerret turbo, waste gated (pending).
Xeonpony is offline
post #6 of 15 (permalink) Old 04-17-2016, 03:01 PM
Yeah. I wasted a few O rings making it right.
Train Horns:
post #7 of 15 (permalink) Old 04-18-2016, 08:17 AM
My Photos: (27)
I used to reseal all types of dozer hyd rams, banks of control valves in graders, etc, and I'm sure not disagreeing with Chuckster, but most of the time the round O-rings get mis-shaped over time and are somewhat flattened with age. Any chance that's the case here, Chuck? My heater plastic terminal cracked with age so I replaced the complete ass'y about 6 years ago but I can't remember if it had quad rings (square sided) or regular O-rings.
LMJD is offline
post #8 of 15 (permalink) Old 04-18-2016, 09:16 PM
O ring may have been round, being installed for 24+ yrs may have made it look square. I know I couldn't get a round one in, but once I squared one or three off, I got it to fit snug.
Train Horns:
post #9 of 15 (permalink) Old 04-18-2016, 11:10 PM
Bill1013's Avatar
Just do away with the heater, there useless. Drill and tap the hole for a 1/2" NPT pipe plug.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
post #10 of 15 (permalink) Old 04-19-2016, 07:54 AM
Useless till it gets cold out!
Xeonpony is offline
post #11 of 15 (permalink) Old 04-19-2016, 08:12 AM
My Photos: (27)
When this came up before I thought I saved my old leaking heater, but when I looked for it evidently I'd trashed it. And my O-rings weren't leaking, I could have measured them and maybe ID'd them.
LMJD is offline
post #12 of 15 (permalink) Old 04-19-2016, 01:12 PM
Bill1013's Avatar
According to Fords manual, the key has to be left on for 5 minutes prior to starting to make the filter heater to heat the fuel enough to be effective, then key OFF then ON to cycle the glow plugs, then start.
Many many have deleted the heater as I've said for the reason the damn things leak and air intrusion.
Your truck, but do as you want.
The PSD's have the heater at the bottom of the fuel bowl, higher wattage, more effective.
Bill1013 is offline
post #13 of 15 (permalink) Old 01-26-2018, 01:06 AM
Found this on a different form go to IH and ask for part # 1811053C1 not sure what they run but I found 1 on Ebay for about $10.00. Kind of Pricey but beats $130 for a new Heater Assembly
COTom1 is offline
post #14 of 15 (permalink) Old 01-26-2018, 09:34 AM
My Photos: (27)
Found quite a few pics of it on Google going by that IH part number and it does appear to be a O-ring rather than a quad ring (square sided). Mine had a cracked plastic terminal due to age and heat and FYI I found out later the heater ass'y is 1/2 the price from IH truck dealership than from my friendly Ford dealer. It came in a typical FoMoCo blue/white box but was in an IH wrapper with the IH part number on the wrapper.
LMJD is offline
post #15 of 15 (permalink) Old 01-27-2018, 12:33 AM
Weird because all of the Pictures of the F2TZ9J294A Fuel heater show O-rings! That may have changed with later models. Where Ford had a better Idea and put the heater rear center of the engine.
COTom1 is offline
