Gauge wires question - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 02-09-2013, 09:55 PM Thread Starter
AUcobra94's Avatar
Where do you guys run the wires through the fire wall? Do you drill a hole or is there a gromet somewhere that I can use?
92 F-250 7.3 IDI (banks turbo), E4OD, 3:55, 4x4
AUcobra94 is offline
post #2 of 4 (permalink) Old 02-09-2013, 10:03 PM
chuckster57's Avatar
I used the plate that covered the hole where the clutch rod would go. I drilled it big enough for all my wires, and air lines for my air bags. I used a piece of wire loom to cover the edge, and when I was done I squeezed a bunch of silicon over the hole.
Sent from AutoGuide.com App
Train Horns:
PM please not visitor message
chuckster57 is offline
post #3 of 4 (permalink) Old 02-09-2013, 10:12 PM Thread Starter
AUcobra94's Avatar
Great, I was looking under the passenger side and found a gromet in the door but really didnt like the location.
post #4 of 4 (permalink) Old 02-09-2013, 11:37 PM
I used the clutch cover plate on the fire wall and the grommet on the heater ducting.
1993 7.3 IDI, crew cab, long box, 4x4 and a half, XLT with ATS turbo.
Glowshift Boost, Trans, Pyrometer gauges with glow shift pod.
Devdg is offline
