Growling noise when coming to a stop - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By DENNY
post #1 of 7 (permalink) Old 11-15-2019, 03:32 PM Thread Starter
My 94 f250 7.3 with E4od transmission is making a loud growling noise when slowing down or coming to a stop. Just got done adjusting my throttle position sensor. At times the noise will go away when I put it in neutral but not always. Noise is intermittent but seems to be getting more frequent. No lights showing a problem. ANY help would be greatly appreciated..Jimbo
Jimbojcs is offline
post #2 of 7 (permalink) Old 11-15-2019, 05:39 PM
ArcticDriver's Avatar
So the noise has nothing to do with applying the brake pedal?
NOS Black CPS. ScanGauge-II. Bilstein 5100. Stancor GPR. Walker BTM. Noco Mod. Michelin Defender LTX 285/75/16.
SOLD:
ArcticDriver is online now
post #3 of 7 (permalink) Old 11-16-2019, 08:45 AM Thread Starter
It sounds like metal on metal “brake pads” but pads are in good shape. Sometimes upon applying the brake it seems to “turn on “ the growling sound but it will also do it by just slowing down.
Jimbojcs is offline
post #4 of 7 (permalink) Old 11-16-2019, 02:10 PM
In order to isolate the cause, I would raise the wheels and spin each one by hand to see if they grind or are loose. This will troubleshoot the brakes and wheel bearings and drivetrain and allow you to get closer to the sound while the engine is off.
SOLD:
post #5 of 7 (permalink) Old 11-17-2019, 12:13 PM
Do you have the noise if the truck is sitting still? If so it is not the Brakes. Your tranny is going bad.
DENNY
ArcticDriver likes this.
DENNY is offline
post #6 of 7 (permalink) Old 11-17-2019, 03:18 PM Thread Starter
Checked all the brakes/wheel bearings etc yesterday. All good. I’m leaning toward Tourqe converter as truck has begun to make noise at a stop as if it is still engaged. Possibly solinoid pack in transmission may be involved??
Jimbojcs is offline
post #7 of 7 (permalink) Old 11-17-2019, 04:28 PM Thread Starter
Or could it be the “tss” Tranny speed sensor??
Jimbojcs is offline
