Hard brakes - Diesel Forum - TheDieselStop.com
 1Likes
post #1 of 19 (permalink) Old 06-30-2018, 06:36 PM Thread Starter
Hard brakes
I have replaced the vacuum pump, the master cylinder, the brake booster and my brake light is still on and hard brakes, any idea?
Timbo813 is offline
post #2 of 19 (permalink) Old 06-30-2018, 06:41 PM
bugman's Avatar
My Photos: (12)
Have you tested the vacuum at the vacuum distribution manifold?
Not by just putting your finger on it but a actual gauge.
bugman is offline
post #3 of 19 (permalink) Old 07-01-2018, 11:05 AM
What should that be? I have always just put my finer over the hole, and guessed. "Micrometer eye...budweiser elbow"
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #4 of 19 (permalink) Old 07-01-2018, 11:52 AM
bugman's Avatar
My Photos: (12)
I believe that it should be around 18Hg on a vacuum gauge.
While the finger and elbow test works but if you are having problems that could be related to a low vacuum issue I would think that you would want the actual reading.
bugman is offline
post #5 of 19 (permalink) Old 07-01-2018, 02:32 PM
I agree, that's why I asked. I'm having a vacuum problem, pretty sure it isn't the pump, 'casue it comes and goes. A pump usually just fails. I haven't tested anything yet, just started the end of the week. I want to catch it when it isn't working.
post #6 of 19 (permalink) Old 07-01-2018, 03:11 PM
bugman's Avatar
My Photos: (12)
When I was working I was a trouble shooter for the company and I always told people that if it was broke I could fix it. It is wasn't or if it was a come and go type of trouble that it would usually be a lot harder to fix. That is when you need to drag out the manuals and start making sure that things are within spec's . But at times you have to go with your best guess and go for it.
bugman is offline
post #7 of 19 (permalink) Old 07-01-2018, 04:00 PM
I've told many supervisors, that if I knew what was wrong, I'd have it fixed, then asked them to please not help, because it would take much longer to figure it out.
post #8 of 19 (permalink) Old 07-01-2018, 07:13 PM
chuckster57's Avatar
Looked at my photobucket pics since I cant post pics. When someone asked a few years ago I hooked up my vac gauge to the vacuum manifold. Idling I had 25.5 inches of vac. Pressed brake pedal, dropped to 21 and took 5 seconds to recover.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #9 of 19 (permalink) Old 07-01-2018, 08:15 PM
Will not get that at higher elevations, Got to really work to get close to 20 here, think it is more around 15 to 20.
Randy 4614 is offline
post #10 of 19 (permalink) Old 07-02-2018, 07:35 AM
My Photos: (27)
I found a chart once and I think at 5000 feet it showed something like 19 or 20. I don't know if this applies to all older model years, but most people don't know that the plastic inlet fitting at the vacuum booster is a one way check valve to keep max vacuum in the booster.
LMJD is offline
post #11 of 19 (permalink) Old 07-02-2018, 07:40 AM
79jasper's Avatar
Iirc, the check valve was the "zero loss booster."
There was a tsb about it.
Or are they all a check valve?
Sent from my SM-G892A using Tapatalk
79jasper is offline
post #12 of 19 (permalink) Old 07-02-2018, 08:57 AM Thread Starter
I have not tested the vacuum manifold with a gauge, just the finger test, does it need to be a special guage to test the vacuum, sorry I am new to desiels. Is the vacuum manifold the little square box that the vacuum hose runs To? Thank you guys for all your help.
Timbo813 is offline
post #13 of 19 (permalink) Old 07-02-2018, 04:08 PM
Yes that's it. Driver's side fender well, right where you can "easily" reach it. Didn't know that about the check vave, I think I'll check mine there, might be what is wrong, by the way it is acting.
Any good vacuum gauge will work
post #14 of 19 (permalink) Old 07-02-2018, 09:54 PM
If you have the Tomato Can on the drivers side fender, that is a reserve for one time braking and also for cruise, they do rust thru small holes, vac pump has a hard time try to keep up.
92 F350 Lariat, 2WD, Dualie, CC, LB, E4OD Trans, Banks Sidewinder turbo, GV O/U, Pyro, Boost, Oil temp, Trans temp. Chassis 129K, Engine 7.3L 75K. Bench seat.
"99.5 F350 7.3 PSD 4R100 CC LB 4X4 DRW 4:10 Centurion Conv.
ScanGaugeII SPDiesel Performance Module 40-60-80 HP -- A Pillar - Boost - Pyrometer - Trans.Temp. - Engine Oil Temp.GN Hitch 20K -- Reese 16K 5er Hitch - Draw Tite Brake Control - Aux. Trans. oil cooler - 100 Gal. Transfer Flow fuel tank, W/Trax II computer. DIY black bed liner. Red Knight
IDI firing order 12734568--------1&4-2&5-7&6-3&8 Cyl's @ TDC. 1&4 TDC when timing mark is @ 0. Each 1/4 turn, next 2.
Trucker87 is offline
post #15 of 19 (permalink) Old 07-03-2018, 05:38 PM
Thanks Trucker, now I have two directions to lean
