heater problems - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 10-22-2019, 08:56 PM Thread Starter
heater problems
starters. my heater core has sprung a leak how is the best way to remove and replace it? second question is i get heat in the vents but not much pressure behind it. ive tested to see if the fan is working like it should it is. what else could cause this?
90 f350 2wd 7.3idi non T 5speed
DevilDog6154 is offline
post #2 of 7 (permalink) Old 10-23-2019, 02:26 PM
If I remember right, the heater core is accessed by removing the glove box, and some of the covers under that side of the dashboard. As for the weak vents, it's hard to say by looking at a 'puter screen. Look for broken ducts, and look at the mixer door.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #3 of 7 (permalink) Old 10-23-2019, 08:50 PM Thread Starter
thanks
post #4 of 7 (permalink) Old Yesterday, 09:16 AM
caseyj's Avatar
Every year, I have to pull the blower motor out of my heater to remove material left overs from mice. What happens is that they build their winter nests ahead of the heater core and it is than sucked into the core which plugs up the air flow. I store my truck each winter so this may not be an issue with everyone. I have tried moth balls and other preventatives but the problem returns each year.
caseyj is offline
post #5 of 7 (permalink) Old Yesterday, 07:57 PM
Also if the little plastic line going to the ac box under the hood cracks causing low vacuum to the door. happened on mine , fixed it helped mine. Might be worth a check .
Randy 4614 is offline
post #6 of 7 (permalink) Old Yesterday, 11:08 PM Thread Starter
Thanks. I use my truck year round so no mice problems should be there. I think that hose is messed up on mine.
post #7 of 7 (permalink) Old Today, 10:10 AM
My Photos: (27)
I'm with oldrebuiltdodge, it comes out from the glove box area. It's been a long time, but best I can recall it's a pretty easy job compared to other vehicles.
LMJD is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
