help 1994 e-350 7.3 non turbo - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 05-01-2019, 07:13 PM Thread Starter
when i first start it up i can hear like a burp burp burp noise coming from the intake hose that attaches to the airfilter i know thier is some kind of flap valve where a carb would be and it sounds like it from thier on happens sometimes and i have to shut it off then restart it then it is fine is this something that is spring loaded or what controls it ? van runs great this started like a week a go any help and pics any advise how to fix it ??? thank you
dutyhole is offline
post #2 of 4 (permalink) Old 05-02-2019, 05:52 PM
The intake is wide open through the air filter. Engine speed is controlled by the foot feed attached to the injector pump, which will supply more or less fuel. The noise you hear sounds like (from your description) it might be an intake valve hanging slightly open, or maybe leaking. If it hangs too far it will hit the piston, but just off seat probably not.
1993 F-350 crew cab non-turbo 5 speed transmission
35 years a mechanic on large stationary engines natural gas and diesel fired, and other industrial equipment.
oldrebuiltdodge is offline
post #3 of 4 (permalink) Old 05-02-2019, 08:34 PM Thread Starter
THAT DOES MAKE SENSE SO I COULD HAVE A WEAK VALVE SPRING THEN ........SO THAT FLAPPER VALVE THAT CONTROLS THE AIR GOING IN THE INTAKE HAS NOTHING TO DO WITH IT THEN ?
dutyhole is offline
post #4 of 4 (permalink) Old 05-03-2019, 08:34 AM
My Photos: (27)
There is no flapper valve, at least not supposed to be. Since there's no throttle plates like a gas engine to muffle intake/combustion noise, what you're hearing is probably normal.
LMJD is offline
Similar Threads
1984 6.9 to 1994 7.3 turbo [email protected] 7.3L IDI Diesels (Not Power Strokes) 3 03-10-2013 05:05 PM
1994 7.3 turbo idi or ps? CAT1150 7.3L IDI Diesels (Not Power Strokes) 26 12-20-2012 10:51 AM
Looking for __Solutions__ to __Prevent__ turbo failures kheck 6.0L Power Stroke Engine and Drivetrain 53 03-13-2008 06:07 PM
1994 F250 7.3 IDI Turbo Pat1920 7.3L IDI Diesels (Not Power Strokes) 6 03-06-2008 12:11 AM
Blow by test 1994 F250 7.3 IDI factory turbo Pat1920 7.3L IDI Diesels (Not Power Strokes) 1 02-28-2008 08:48 PM
